Cossie leccy windows not working
Old Jul 10, 2004 | 05:54 PM
maulordracos's Avatar
maulordracos
Default Cossie leccy windows not working
Can anyone help, gotta a problem with my leccy windows.
Checked switches, found no feed but the fuse is ok. Only seems to have happened since I changed the starter motor??? Doubt thats done it, but any ideas or wiring guidance?
Old Jul 11, 2004 | 10:00 AM
James's Avatar
James
Did you knock any wires off from the battery?
Old Jul 11, 2004 | 11:30 AM
maulordracos
dont think so, there are only 3 wires to mess with on the contacts, 1 on the live and 2 on the negative...
seems really strange, dont think its the relays but not sure which one to check if it is. Stranger thing is, i dont think its the buttons by the handbrake as the ones in the rear dont work either..
Old Jul 11, 2004 | 04:46 PM
foreigneRS's Avatar
foreigneRS
Testing the future
is it 2wd or 4x4?
on 4x4, the window switch unit has a connector in the loom under the centre console effort in front of the gear lever. check that this is still together.
Old Jul 14, 2004 | 10:17 PM
maulordracos
its a 2wd ...
liam-rst
Aug 10, 2015 08:46 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
