Actuator setting
Old Nov 22, 2005 | 01:57 PM
Hrsturbo's Avatar
Hrsturbo
Default Actuator setting
I just fitted my electronic boost controller and has settings for hi and low boost, I have a -31 actuator, what boost shall I set this to before setting the boost electronically?
cheers
Old Nov 22, 2005 | 04:27 PM
SamERST's Avatar
SamERST
free bump cos im interested lol
Old Nov 22, 2005 | 04:56 PM
andysrs's Avatar
andysrs
Default depends on your engine spec
mine runs 8 and 18 but then the motor is far from standard be careful you dont want to put a rod threw the block by running silly psi if you have a standard motor
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
