Ive sorted out the camshaft oil seal but.........
Old Nov 19, 2005 | 08:06 PM
GraphiteGray's Avatar
GraphiteGray
Default Ive sorted out the camshaft oil seal but.........
......now theres a dull spealing noise coming from the area around the cam pulley when i rev it up
Following on from this:
https://passionford.com/forum/viewto...176&highlight=
I greased the oil seal before refitting, ive fitted it flush to the side of the head and it seems okay but theres now this spealing noise, dunno whether its this or the timing belt as theres a strange wear/rubbing mark appearing on the belt
what is going on with my engine?
Old Nov 19, 2005 | 08:17 PM
320 bhp's Avatar
320 bhp
timing belt could be too tight
Old Nov 19, 2005 | 08:40 PM
GraphiteGray
you know ive got a funny feeling it might be a little tight, will check it tomorrow
Old Nov 19, 2005 | 08:45 PM
320 bhp's Avatar
320 bhp
if its tight it will make a noise the more u rev it i was alway told when the cars cold u should be able to twist the cam belt 1/4 of a turn on it longest point if u no what i mean.
in your case from bottom pulley to th cam is the longest point take hold of the belt 1/2 down and see if u can twist it 1/4 turn that what i was told by a bloke that works at ford but im sure sum1 on here will say otherwisw good luck
Old Nov 19, 2005 | 10:01 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
give the belt a yank on the longest part also you should feel a good whip on it, if you know what i mean if not then ignore
Ian1964
12
Jan 26, 2021 11:57 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
Marino
Sep 12, 2015 11:10 AM
hopper350
Sep 4, 2015 12:53 AM
