Heater Control nobs
Old Nov 19, 2005 | 05:11 PM
Matt_B's Avatar
Matt_B
Default Heater Control nobs
does anyone know how to remove the heater conrol nobs on a S2 RST? The left hand one just pulls of but the other 2 are stuck solid. Any ideas?
Old Nov 19, 2005 | 05:13 PM
dave_y's Avatar
dave_y
they just pull out too.
Old Nov 19, 2005 | 05:15 PM
Matt_B's Avatar
Matt_B
they def aren't coming without a fight
Old Nov 19, 2005 | 05:19 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
yep.you have to remove the two screws to release the whole panel,then carefully prise the thing off when its away from the dash,beware as ford sells the heater switch for 35 quid.
its a bummer to do,yours must be stuck like mine was
antony215's Avatar
antony215
Escort Rs Turbo
they deffo pull off mate just some of them are hard to get off i get a flatended screwdriver behind them they soon come off then
Old Nov 19, 2005 | 05:28 PM
akito-man's Avatar
akito-man
that so,!!!!!!well i broke mine ,! thats how i know the price,!!!!!take the two outer knobs off and there are two screws ,take them out,then pull the panel up and off,disconnecting the heater direction cable,,and the light wire,and also the power block connector,then you will see the heater switch has two push in clips to remove the servo unit,then you can push her thruogh the panel,trying to pull off the knob (ooo err) will end in a broken switch.if you want to try to remove the welded on knob-end then ,thats up to you,like i said ,mine broke.
yours must be a pre 90 car like mine then.
Old Nov 19, 2005 | 05:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
akito-man He's not on about taking the panel off he just want's the control nob's off
Old Nov 19, 2005 | 05:38 PM
Matt_B's Avatar
Matt_B
i do need the panel off though as well cos i have got a 3 gauge pod thing to go in its place, even though 2 gauges are broke
Old Nov 19, 2005 | 05:52 PM
antony215's Avatar
antony215
Escort Rs Turbo
once you've got the control nob's off then you will see the two screw's that akito-man is on about undo them then unplug the plug for the lights on the heater panel then it will come out
Old Nov 19, 2005 | 07:25 PM
ivorbiggun's Avatar
ivorbiggun
Be careful when undoing the two screws cos the plastic lugs that the screws got thru tend to disintigrate.
Old Nov 20, 2005 | 10:27 AM
akito-man's Avatar
akito-man
aye true,i used them foldover metal retainers to screw into
Old Nov 20, 2005 | 10:31 AM
akito-man's Avatar
akito-man
the right one will have to pull off,my centre heater knob was the bas,of all basses,and thats the 35 quid one that broke! thats why i tell thee,to take the panel off to try and remove the heater knob when its away from the dash,maybe penatrating fluid or something.
is it a pre 90 car then??????????????
Old Nov 20, 2005 | 01:25 PM
Matt_B's Avatar
Matt_B
yeah its on a G plate, spent all day yesterday fittind a TV and dvd player into so dont know if i can be arsed wasting another day pissing about
Old Nov 20, 2005 | 11:24 PM
akito-man's Avatar
akito-man
hammers break em quick
get one from a scrappy outa a 90 spec,they come off ok.
Old Nov 22, 2005 | 12:28 AM
Combi_Chris's Avatar
Combi_Chris
you need a good grip, dont you use spanners ??
i would suggest put a piece if string round one , pull that and the controller itself with your hand
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Flatlinedan
Sep 18, 2015 12:41 PM
