What boost and spec are people running?
My S1, acrilite pistons,cvh 34 cam,polished and ported head,-31 actuator,cone filter.pace intercooler(small) NOT FRONT,hybrid turbo running 2wd cozy internals,2 stage boost,8 low 18 high 200bhp
Stage 2 1600 cvh engine with ported + polished head
Low comp mahle pistons
Stage 3 T34 hybrid turbo
-31 Actuator
Ahmed bayjoo fully mapable chipped ecu running 20psi
Full Mongoose stainless steel exhaust system
Custom ram air induction kit
Uprated bigger intercooler
Full samcos
Where do you get this 2 stage boost from ? as i want it to run about 7psi norm and 20psi on high.
Sam
-31 Actuator
Full samcos
Sam
1658 acrilite pistons
steel rods
l/b bottom end
big valved gas flowed efi head with piper t2 cam
jamsport inlet manifold with 2wd cossie tb and light blue injectors
stage 3 t34 with 3inch exhaust and twin side exit
gotech engine management 2bar boost
steel rods
l/b bottom end
my engine isnt finished yet but im planning 2 bar from my Esc Cos t34 on zetec turbo with steel bits, cams, headwork, tubular manifold, m16 inlet etc
any pics of the side exit? im intrigued... to see what it looks like
steel rods
l/b bottom end
steel rods
l/b bottom end
My spec once I got my shell back will be
Cossie management, 803's, standard bottom end with de-comp plate, standard T3 and 2wd coolers untill i get my money for my PROPER engine, hoping for 300+bhp that spec
Smart that! Its got the look i like, Not bufty, more functional
steel rods
l/b bottom end
steel rods
l/b bottom end
1.8 cvh
mahle low comp forged pistons
H beam steel rods
arp bolt set
polished and ported big valve head
kent cvh 35 cam
kent vernier pulley
turbo technics stage 2 hybrid turbo
-31 actuator
GRS intercooler
223 bhp, 236 ft/lb torque at 14 psi boost
H beam steel rods
arp bolt set
kent cvh 35 cam
kent vernier pulley
-31 actuator
GRS intercooler
1618cc CVH, stage 2 big valve head (ported and polished), Newman cam, solid lifters, piper vernier, wire ringed block, lowered compression(7.5:1), ARP conrod Bolts, heavy duty bearings, high pressure oil pump, AVA ecu, 7000rpm limiter, AVA modified fuel system, AVA high flow tubular manifold, T28 turbo, 360 bearing, reshaped cosworth front pipe, AVA Large capacity intercooler, samco water and boost hoses, magnecor leads, magnex exhaust, modified airbox, AP 4 paddle clutch.
240 bhp with 16psi boost
power engineering blueprint motor ,inc head and cam
turbosystems chip -31 actuator,k&n panel filter
one peice stainless exhaust ,14 psi
183 bhp 213 torque proven on 12/11/05
overview....2.1 zvh, stage 3 big valve head, accralite oversized pistons, Piper T2 cam and pulley, stage 3 hybrid T3 turbo, Radtec FMI, Scorpion 3", Omex 500 management on EFI
proven 235hp at 14psi
This is all before it came of the road end of october...expect few changes after the new year
mines in the process of bein built!
2.1 zvh
steel rods
forged pistons
l & b bottom end
custom head, the usual big valves and massive ports all match to inlet and exhaust manifolds
custom newman cam with double valve springs and solid lifters
t34 hybrid
p8, anti lag, coil pack and motorsport blue injectors
water injection
loads of other stuff
mix it all together
and im hopein for roughtly 320 bhp and the same torque! at about 20psi and should make 350 on about 2 bar
2.1 zvh
steel rods
forged pistons
l & b bottom end
t34 hybrid
water injection
mix it all together
Bottom end,low comp mahle pistons running 7.8.1 comp
Stg3 burton power head&kent cvh35 cam&vernier pully
4x4 cossie turbo with .48 housing from saab turbo& -31 actuator
Full stainless mongoose exhaust 4” tailpipe
Grs front mount intercooler&slim line fan
super chip ecu running 18 psi at moment
Magnicor spark plug leads
Modified fuel ecu
Modified air filter
needs more boost and setting up though
Have got a diff bottom end which i will be getting sorted soon which has had a few £££s spent on it
Modified fuel ecu
Modified air filter
Originally Posted by Tony Turbo
Standard engine, turbo, cam and intercooler. With a bleed valve and dump vale, running 3 bar boost
sounds some thing like an add off ebay for a 400bhp rs
Was running
1600cvh with AVA custom inlet(with throttle boddies) custom exhaust manifold, RS500 intercooler, T3 Turbo@ 28(ish) PSI. 228bhp @Wheels
Currently having built Series 3 2.0ZT with Steel Rods, JE Pistons, T38 Turbo etc etc. Retaining the AVA Manifolds and Throttleboddies.
efi head ported and inlet matched
285t2 cam double springs
2l block new
focus wrc rods and pistons
stage 3 t3
green injectors
l6 with pectel baby board till p8
bhp= just got to be put togother then run in next week hopefully
2l block new
stage 3 t3
green injectors
heavy duty bottom end
piper 285T cam
Magnecor Spark Leads
195bhp Ahmed Bayjoo Chip
stg 2 hybrid turbo (55 trim .36 housing) -31 actuator
2wd cosworth front mount intercooler
pace alloy radiator
k/n Panel filter
rebuilt lsd gearbox
AP organic clutch cp2000-8
modified clutch pedal frm mk6 escort
lightened balanced flywheel
scorpion 3.5'' exhaust
thats the spec of mine. needs settin up tho as its goin up to 19psi odd wen i plant the accelerator which im worried is too much as im not clued up on rs turbos and have only just got the car
piper 285T cam
pace alloy radiator
k/n Panel filter
rebuilt lsd gearbox
. Will get sum better 1s tho
