Flutter
Old Nov 18, 2005 | 11:14 PM
S2_Steve's Avatar
S2_Steve
Default Flutter
What do I have to change to make that fluttering noise rather than have a a dump valve, I know most people dont like them but the car was set up with it on (aleady set up when i bought it) and am abit werry of taking it off!
but I love that fluttering noise,
I couldnt tell you spec of the car as all I know is its chip and running 13psi but peaks at 15psi, have a big front mounted intercooler on it, with a pipercross induction kit on it with a garrett t3 airsearch turbo on it (i are t3 but please correct me if wrong)
Thanks for your help in advance
Old Nov 18, 2005 | 11:20 PM
JimmyBoy's Avatar
JimmyBoy
That "fluttering" noise is called chatter.
Need to conver the car to efi, and take dump valve off.
Old Nov 19, 2005 | 12:34 AM
adamS2RST's Avatar
adamS2RST
Yes, if the car is still running the original management system you wont get the flutter. As mentioned you need to convert to fiesta turbo efi or cosworth management / aftermarket etc, basically anything that ditches the fuel metering unit as that is what stops it from making the noise
Old Nov 19, 2005 | 09:29 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Just lose the d/v and try it.
You can get chatter with mfi, but efi is louder & more prominent.
Old Nov 19, 2005 | 09:39 AM
adamS2RST's Avatar
adamS2RST
Chatter with MFI is minimal though....and if it is loud you got a leak somewhere
Old Nov 19, 2005 | 01:46 PM
addiction's Avatar
addiction
the correct name is compressor stall!!! i run with mfi and she chirps like a good un.
Old Nov 19, 2005 | 02:33 PM
Oranoco's Avatar
Oranoco
Snap!
Although it doesn't sound nearly as impressive after driving the Fiesta
Old Nov 19, 2005 | 03:49 PM
JimmyBoy's Avatar
JimmyBoy
I dont really understand everyone's obsession with it TBH. It's ok for the first couple days that you got it, but then it just irritates the crap out of ya. No different to a dump valve in that respect - ie irritating noise everytime you change gear.
Old Nov 19, 2005 | 04:07 PM
adamS2RST's Avatar
adamS2RST
Each to thier own
Old Nov 19, 2005 | 07:51 PM
zippyobrien's Avatar
zippyobrien
chatter is much better than a dump valve, louder too if you run enough boost.
i think chatter has a more individual sound, i also think it is more provoking, makes you want to cane the car even more.
ive got pretty loud (louder than bailys dv24) on mfi with no air leaks (had it checked after reading a similar post.
Old Nov 19, 2005 | 08:01 PM
©hatter Box's Avatar
©hatter Box
whos ur daddy for chatter when u heard mine ur want it for life
zetecdan
Apr 17, 2008 10:30 PM
R5FORD
11
Sep 15, 2007 07:41 AM
Lee Reynolds
56
Jul 13, 2007 07:20 AM
Mk2_2dr_2L_Escy
Jun 4, 2007 03:32 AM
AJC
Nov 3, 2005 06:36 PM
