tips on welding floor pans
Old Nov 18, 2005 | 09:21 PM
s1 2oobhp's Avatar
s1 2oobhp
Default tips on welding floor pans
has any1 got any tips on welding floor pans in a mk3 escort as all 4 need doin cheers
Old Nov 18, 2005 | 09:46 PM
mmanse's Avatar
mmanse
have done a couple
cut a grind rust out then take time cutting the plate's
i took all interior out and plated on the inside then welded the under side
to the plates then ground it down smooth so would not notice from
under the car.
done this a couple of years ago and still looks good
Old Nov 19, 2005 | 12:50 AM
harvcore's Avatar
harvcore
i find that the best tip is
always keep breathing ,it works for me ,oh and take your time if its
done proper first time it dont need done again .
Old Nov 19, 2005 | 05:36 PM
s1 2oobhp's Avatar
s1 2oobhp
cheers lads
Old Nov 22, 2005 | 08:11 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
And make sure you get someone to 'spot' for you - set fire to the underseal on mine by accident and didn't notice until i had a roaring fire against my skirt
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Orion_Gav
Sep 29, 2015 04:50 PM
youngben
Sep 27, 2015 09:37 PM
