boost pipes too soft
Nov 18, 2005 | 06:45 AM
as above its very very soft the pipe big one that cums rite off the turbo would this stop my car boosting well ?
also amul vavle sumone told me to plug it off and stopp running it why ?
Nov 18, 2005 | 10:27 AM
if you unplug the amal valve it'll boost to 11-12psi iirc
wouldnt advise just unplugging it.
soft boost pipe may colapse under load (boost) stopping the car from pulling
Nov 18, 2005 | 11:23 AM
Soft hose from metering head to turbo will cause a problem. Get yourself some nice new Samco's. As the old hose deteriates they get soft and collapse under boost.
Nov 18, 2005 | 03:39 PM
would that explain why when i boost it pulls hard for a split second then lose the boost ??
Nov 18, 2005 | 05:17 PM
Sounds like the hose squishing under the boost. Best get the wallet out and buy a posh set of Samco's for it
Nov 18, 2005 | 05:30 PM
Buy a metal one . turbo to metering head. pipe..
Nov 18, 2005 | 07:01 PM
does it really make a diff ? i think ill buy it 2moro it boosts nice but seems to stop at 4000rpm and it only spools a 2500 poo poo
also moneys a bit tight at mo would a new std ford item be just as good ?
ive bought sum new sparks and leads both from ford as sum say there the best but again got told they could melt under big boost ????
Nov 18, 2005 | 07:13 PM
They'll prob sting you a fucking fortune for it. Bro was stung £50 for 1 hose on his FRST
Wait until payday and get some silicone jobs
Nov 18, 2005 | 07:31 PM
power engineering
Got these on my s1 there as hard as a bulls foot very nice
Nov 19, 2005 | 09:24 AM
Or get a set of roosemotosport hoses. Cheaper thansamcos, but better quality
Nov 20, 2005 | 12:55 PM
as above, ring paul and get a set from him, does loads of colours, yellow and silver look sweet!!!!
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
mpilk
Sep 27, 2015 09:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
