series 1 rear disk conversion problems
Old Nov 17, 2005 | 08:32 PM
escort frenzy's Avatar
escort frenzy
Default series 1 rear disk conversion problems
I'm having alot of trouble getting a good brake pedal. I've just put 2wd drive cossy brakes on the rear and now i can't get a good pedal. I've put a new master cylinder on and new braided hoses. I've bleed the system about 4 times and theres no air in the system and still a s**t pedal. Do you have to by-pass the rear brake compensator as thats the only other thing i can think of?
Old Nov 17, 2005 | 09:36 PM
MikeyXR2i's Avatar
MikeyXR2i
Im pretty sure only the S2's have the rear Brake compensator.
Old Nov 17, 2005 | 09:52 PM
escort frenzy
now i think about it is only S2's the have them
Old Nov 17, 2005 | 09:57 PM
MikeyXR2i's Avatar
MikeyXR2i
When i changed to Cossie Calipers and disks all round on my XR2i, the pedal went crap, the car would stop but not like it should, i changed the master cylinder to a MK5 Escort Item, and the braking was transformed, everyone that has driven it comments about the brakes.
I bet ya pedal is spongy and the brakes only start to bite when the pedal is 3/4 the way down?
Old Nov 17, 2005 | 10:04 PM
escort frenzy
Yup I've put a brand new master cylinder on it as well.
Old Nov 17, 2005 | 10:14 PM
MikeyXR2i's Avatar
MikeyXR2i
May have to try bigger diamater master cylinders with a shorter stroke, as the MK3/4 escort one is quite long.
Old Nov 18, 2005 | 09:58 AM
Wazzzer's Avatar
Wazzzer
I think we've had this one before, if you look at the back caliper the bleed nipple isn't as upright as it should be and is prob holding a bit of air in the caliper
best thing to do is take it off but leave it gripping the disc and move it down so the bleed nipple is 100% vertical then bleed again
I think it was Adam Black RS that had this prob
Old Nov 22, 2005 | 02:00 PM
SafeChav's Avatar
SafeChav
Just for info, a mk5 escort master cylinder is in actual fact the same size as a mk4 90 spec cylinder??
Ive got the 2wd cossie set up on my cabriolet and my pedal isnt fantastic, fair bit of travel and not that responsive, they are definately bled, as before the pedal went to the floor.
I cant see how putting a mk5 item on is going to benefit if it is the same diameter?
anyone got any ideas?
Old Nov 22, 2005 | 03:53 PM
adamS2RST's Avatar
adamS2RST
And me....
See if these links help you....in the second thread notice the comments made by ON-UJAH He makes a lot of sense
https://passionford.com/forum/viewto...204&highlight=
https://passionford.com/forum/viewto...758&highlight=
Old Nov 22, 2005 | 03:55 PM
adamS2RST's Avatar
adamS2RST
I think it's in fact the MK5 Fiesta MC that is fitted for a better pedal, although it's not a straight fit. But I know Matt zvhturbo off here has done it and he said it was good. I didn't bother in the end now I have fully removed my ABS my ST fronts and Cossie rears are fantastic
Old Nov 22, 2005 | 03:57 PM
SafeChav's Avatar
SafeChav
i dont have ABS or rear load apportioning valves on mine, im struggling with this set up, guna end up taking it back off soon i reckon its starting to get annoying.
Them Fiesta master cylinders are pea shooters man lol, look well pathetic???
Old Nov 22, 2005 | 04:06 PM
adamS2RST's Avatar
adamS2RST
Right, have a look here if you want more info on it: https://passionford.com/forum/viewtopic.php?t=59245
I have retainted my rear load valves, have my ABS removed and the brakes are good. I DID however initially have a terrible pedal, which believe it or not got better over time.... I did bleed the system a few times and in the end got an eezibleed pressure kit which worked well I think my problem was mainly not because of how the rear calipers sit as I never needed to remove mine to bleed but because my brake lines were drained of fluid for about 8 months they were completely dry, same goes for the MC, how I did'nt fook the seals on it I don't know!
Old Jun 30, 2006 | 03:05 PM
16vzetec's Avatar
16vzetec
master cylender is too small for bigger brakes
Old Jun 30, 2006 | 10:02 PM
DazC's Avatar
DazC
I have 2wd Cossie rear calipers and AP 4 pot calipers on the front all being worked by a standard master cylinder and servo and the pedal is mint beyond mintyness.
Try bleeding the system again starting from furthest away from the master cylinder and work closer. Take the calipers off and hold them so that the bleed nipple is pointing upwards if neccessary.
Old Jul 2, 2006 | 03:03 PM
SafeChav's Avatar
SafeChav
Tried all that, and it made the brakes actually work where as they didnt before.
Pedal is still shit though, passed its MOT though.....so im lost as to whether theres air in the system or not
Running a 23mm aswell, i presume yours is 22mm Daz?
Oct 9, 2015 07:38 PM
marky_g
18
Aug 26, 2015 03:42 PM
RsS2daz
Aug 14, 2015 05:26 AM
dlwarrior
Aug 5, 2015 10:19 AM
