under boost pop and bang
Old Nov 17, 2005 | 01:22 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default under boost pop and bang
hi all on my s2 it runs fine from cold no probs
but when it gets warm it seems to hesitate under boost
it will still pull all the way through the gear just hesitate slightly under acceleration pop
some times this happens just as u come on to boost it will pop LOUD out of the exhaust and go a bit flat but does not happen every time u give it large any one got any ideas i think something is breaking down
Old Nov 17, 2005 | 01:34 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
happend on mine too a few times, still dunno why
although it boosts to 12psi when it's set up for 7psi, but it is chipped so i dunno if it's lack of fuel on mine?
or if my plug leads are breaking down as their shit
Old Nov 17, 2005 | 02:10 PM
rs combi's Avatar
rs combi
mine did this i changed the plugs and it was fine
Old Nov 17, 2005 | 02:17 PM
ASHCOSSIE's Avatar
ASHCOSSIE
ive just put oe cossie plugs in about 600 miles ago wonder if the plug gap is wrong anyone know what i should set the gap to?
Old Nov 18, 2005 | 03:39 PM
PaulT's Avatar
PaulT
My mate had similar problem with his car sounding like a machine gun turned out to be a dodgy amal valve
PaulT
Old Nov 18, 2005 | 03:43 PM
zippyobrien's Avatar
zippyobrien
my mates pops when he changes gear, but only in 3rd and fourth and only every now and again? still does it. he is still running the amal valve and 10psi, no chip
any ideas,
p.s got standard o91c plugs gaped to 0.75.
cheers lads
Old Nov 18, 2005 | 03:46 PM
ASHCOSSIE's Avatar
ASHCOSSIE
my one has no amel valve on it i think it may be plugs or the plug gap but i would not have thought that it would have killed the plugs in 600miles but i could be wrong.
Old Nov 18, 2005 | 04:03 PM
zippyobrien
i dsone a set of plugs in 500 miles before, shity nkg ones. the fuelling was wrong on the car but they went aqfter around 500miles?
Old Nov 18, 2005 | 04:08 PM
gary scott's Avatar
gary scott
Throttle switch?? Mine used to do something similar and I changed the plugs, leads, cap, rotor arm and even put a bigger wire into the fuel pump!!
Undone the two screws for the throttle switch turned it back till it clicked and then put it back to the original position and that sorted it out!!
Always worth checking!
Old Nov 18, 2005 | 04:12 PM
zippyobrien
ill tell him to try it,
cheers mate.
i think ive just lost my verginity
wooot wooot
Old Nov 19, 2005 | 12:28 AM
vroooom ptssssh
It Wasnt Me!
i think my anal valve is gubbed
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
