2wd recon diffs
as above £300 or £350 fitted exchange only even if your has gone pop
new bearings fitted
new seals
vapor blasted casings
new planet n sun gear kit fitted
all flanges are zinc coated
new bearings fitted
new seals
the lsd is tested but normally not touched
remember your getting a recon diff unit n planet n sun gear kit for £50 more than 2nd hand fucked units are fetching
work it out what makes more sense
the diff builder builds n supplies all of westfields factory units
pretty good price for a diff which has had new seals ect
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
