uprated s2 fuel pump??where from
Old Nov 16, 2005 | 09:36 PM
stevenebm's Avatar
stevenebm
post whore
Default uprated s2 fuel pump??where from
awrite folks.what fuel pump should i use on my s2 rs turbo.gona be running 250 bhp with cossie management so need a fuel pump up to the job
Old Nov 16, 2005 | 09:41 PM
bassboy's Avatar
bassboy
will the standard ERST not be up to the job? im sure it will be fine?
bassboy
Old Nov 16, 2005 | 09:43 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
There is no such thing as an uprated fuel pump. Standard will be fine
Old Nov 16, 2005 | 09:47 PM
bassboy's Avatar
bassboy
same as 2WD cossies as well IIRC
bassboy
Old Nov 16, 2005 | 09:49 PM
Tony Turbo's Avatar
Tony Turbo
Looks wise yeah, different flow rates
Old Nov 16, 2005 | 09:51 PM
bassboy's Avatar
bassboy
Tony Turbo ahh ok mate
bassboy
Old Nov 16, 2005 | 10:20 PM
adamS2RST's Avatar
adamS2RST
I got a 2wd cossie pump, as you say looks the same, assume it has a better flow rate then as mentioned?
Old Nov 16, 2005 | 10:21 PM
stevenebm's Avatar
stevenebm
post whore
how come p.t.s do a standard one at 90 pounds and an "uprated" one at 190 pounds.thats what got me confused
Old Nov 16, 2005 | 10:24 PM
Tony Turbo's Avatar
Tony Turbo
Sounds to me that they want your pants round your ankles and for you to bend over
A Grp A Cosworth pump isn't even £200
Adam - Yeah, I have a 2wd one too, flow rate is slightly better, but a standard ERST one is up to the job
Old Nov 16, 2005 | 10:27 PM
adamS2RST's Avatar
adamS2RST
Cheers Tone
Old Nov 16, 2005 | 10:30 PM
Tony Turbo's Avatar
Tony Turbo
No worries Adam. Truth is, I only went for a 2wd Cosworth pump because I had to order a 5 Bar MAP sensor from IMA and he didn't have any RST Pumps at that time
Old Nov 16, 2005 | 10:34 PM
DaveEscos's Avatar
DaveEscos
flash c-unt!
i want one
Old Nov 16, 2005 | 10:49 PM
DazC's Avatar
DazC
I have an uprated Bosch fuel pump.
No, it,s not a Cossie one or an 044 one! I have my reasons why though, not because the others cannot provide enough fuel..
Dave, you mean you DON'T have a 5 bar? I thought every one had a 5 bar! Me included!
Old Nov 16, 2005 | 11:20 PM
stevenebm's Avatar
stevenebm
post whore
a wouldnt pay that fae pts a just saw it in prformance ford mag bit where they advertise.so a standard r2 fuel pump will do me then
Old Nov 19, 2005 | 09:09 AM
sIIpinky's Avatar
sIIpinky
I got an uprated fuel pump fm Demon Tweeks, that only cost me £102 all in!! hopefully shud do the job required,as my old 1 was buzzin like a bitch...
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
