boosting trouble
the car boosts well up to 16 psi builds and then when i change and carry on it falls rite back down to -15boost whats up with it?? could it need a new -31?? or anything else u can fink off?
doing me head in also the cars fitted with a paceintercooler,induction kit 195 chip and been adjusted to 16 psi.
it boosts gets to 15 almost instantly feels slow then holds back and doesnt get any quicker till ya change gear as if its holding back or summing ??
anyhelp lads would be sweet
Has the car been setup since it's been adjusted?
everyone gets a tiny bit of boost drop, the actuator is trying to keep the pressure the same over the whole charge system. To just drop 1psi at peak your not doing too bad!!
There is a way of not getting any boost drop though
, but first I'd get it setup, sounds like your timing may need adjusting
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
