Alternator Drop Brackets , needed with T34 & 2wd M/fold
Old Jul 9, 2004 | 11:47 AM
Tony Ryan's Avatar
Tony Ryan
Default Alternator Drop Brackets , needed with T34 & 2wd M/fold
Ive hung my turbo on and its sitting real close to the std alternator position . Does anyone recommend a drop bracket and if so where from ???
Also if using these do you have to angle grinder the loop that sticks out of the block at the bottom or is there another way round this ??
Regards
Tony
Old Jul 9, 2004 | 11:52 AM
3drstretch's Avatar
3drstretch
It's upto you if you get one BUT it aint gonna hurt is it.I noticed this as well so i bought one.Got mine form Forge Motorsport but i think A1 rallysport sell them as well.And Yes you do need to chop off that offending chunk off block.And you can cut it with a good quality hacksaw as if you use a disc cutter your spraying iron fillings everywhere which will rust and cos problemms later on.
HTH
Old Jul 9, 2004 | 11:55 AM
Spiky's Avatar
Spiky
mine seems fine
12k mileage no alternators died yet
Old Jul 9, 2004 | 11:58 AM
Ryan's Avatar
Ryan
as spiky said mine was fine on mine aswell
still got the alternator bracket if your interested tony FOC of course, but it look a standard item, can check tonight if you want mate?
Old Jul 9, 2004 | 11:59 AM
Tony Ryan's Avatar
Tony Ryan
Good point well made stretch ! Its for a racecar so will get a bit hotter than most so i will get one !
Anyone got a spare ???
Old Jul 9, 2004 | 12:05 PM
3drstretch's Avatar
3drstretch
And watch when you fit it.As you need to chop 1 of the bolts down as if you dont you will bend drop bracket.As it push's against block.
Old Jul 9, 2004 | 12:07 PM
Tony Ryan's Avatar
Tony Ryan
Thanks mate , i get what you mean
Old Jul 9, 2004 | 01:27 PM
the original's Avatar
the original
a mk2 rs2000 alloy alternator bracket with polybushes in is a good alternative, sets the alternator nice and low
Old Jul 9, 2004 | 03:21 PM
RichardPON's Avatar
RichardPON
I've always run my 2wd manifold, and NO alternator drop bracket..........
Alternator is shielded, as is the wiring
Old Jul 9, 2004 | 04:24 PM
Phil's Avatar
Phil
Jeebus
I've put one on my Mk1 just in case - its only 5 minutes work to grind/fit and is essential if using a genuine 500 cooler obviously..
Old Jul 9, 2004 | 05:45 PM
Tony Ryan's Avatar
Tony Ryan
Rich ,
That manifold will get real hot on track mate ! I melted several on my 500 even with droppers , so im deffo going to get one for this car .
Mail me if you have a spare one !
Old Jul 9, 2004 | 05:52 PM
SPADGE's Avatar
SPADGE
Tony got your pm chap and the answer is no sorry!
Old Jul 9, 2004 | 06:26 PM
Tony Ryan's Avatar
Tony Ryan
Thanks anyway mate
Old Jul 9, 2004 | 06:30 PM
RichardPON's Avatar
RichardPON
Tony,
I know it gets hot - I used to run without a turbo heatshield
My alternator used to run a custom heatshield, manufactured from a chopped up turbo heatshield.............
Old Jul 11, 2004 | 09:54 PM
Lee @ Fusion's Avatar
Lee @ Fusion
Tony theirs one on ebay mate , do a search on cosworth dunno how long its got left to run ??
Hears the link
http://cgi.ebay.co.uk/ws/eBayISAPI.d...908973279&rd=1
Old Jul 11, 2004 | 10:05 PM
marco polo's Avatar
marco polo
Hi Tony
I have fitted and Rs 500 drop bracket to mine as i was killing alternators everytime i was going out on track even with heat shiled (only on t34) ...if you are going to fit one you would have to grind of the loop bit that the bottom off the 200 block ........
Steve scott sell some of these made in alloy or just get yourself a mk2 rs2000 drop bracket thats in alloy aswell ......
marco
Old Jul 11, 2004 | 10:08 PM
marco polo's Avatar
marco polo
Tony
while your on mate ........where can i get some 210 's 61 the 62's a a touch too big.. i would have to move my bumper up a bit
biggiejody
Insurance
Sep 2, 2015 12:04 PM
kosienutter
31
Aug 22, 2015 09:55 AM
155lee
Aug 14, 2015 11:21 AM
col93saphcos
Aug 7, 2015 03:21 PM
lockie
Jul 31, 2015 10:03 PM
