toe and camber in rear suspension design
Old Nov 14, 2005 | 09:50 PM
xrsi's Avatar
xrsi
Default toe and camber in rear suspension design
what effect does camber and toe have on rear wheels?
doing independant rear suspension for motorsport use on fiesta's for my final year project in uni and would like to be able to incorperate some sort of adjustment into the designs.
if i can use 2 points to adjust camber then i can also adjust the toe by using the same points in theory with careful design and thought.
just wandering if there is any use in working it into the final model.
Old Nov 14, 2005 | 10:17 PM
NUTS RuS's Avatar
NUTS RuS
Either stability at speed or nimbleness through corners depending on the setting
Old Nov 14, 2005 | 10:35 PM
CozzyBrom's Avatar
CozzyBrom
all ready been done on fezzas
Old Nov 14, 2005 | 10:48 PM
xrsi's Avatar
xrsi
i know you have done it brom!
it is basically a project that i can then go into the industry when applying for jobs and say that i was able to design a system from scratch and thought about it as well instead of just copying another already designed system.
i did give you a pm regarding how you go about testing the suspension parts about a month back, i am going to be in canock on thurs, would it be poss to pop round and discuss things more with you? you could try to tempt me to buy some lower arms..
jessie_rs
62
Aug 6, 2019 09:27 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
truffleshuffle
Sep 10, 2015 09:35 PM
