got broadband and it's slow
I have exactly the same probelem! although i delete all my cookies and my Temporary Files, the bugger is still slow! ive had my broadband speed tested and that is ok! I was told it might be summat to do with my Internet explorer? i dont bloody know, im blonde!
all i know is its slow and it winds me up!
any ideas folks?
any ideas folks?
https://passionford.com/forum/viewtopic.php?t=59949
Have a look at this,downloaded it myself and got rid of 47 dodgy programs i was holding.
SpeedUp Your Connection By 20% (Cable Users Only) Windows XP
1.Log on as "Administrator".
2. Run - gpedit.msc
3. Expand the "Local Computer Policy" branch.
4. Then expand the "Administrative Templates" branch.
5. Expand the "Network" branch.
6. Highlight the "QoS Packet Scheduler" in left pane.
7. In the right window pane double-click the "Limit Reservable Bandwidth" setting.
8. On the settings tab check the "Enabled" item.
9. Change "Bandwidth limit %" to read 0.
10. Then go to your Network connections Start=>Control Panel>Network & Internet connections>Network Connections and right-click on your connection.
Then under the General or the Networking tab, (where it lists your protocols) make sure QoS packet scheduler is enabled.
It may take effect immediately on some systems. To be sure, just re-boot.
2. Run - gpedit.msc
2. Run - gpedit.msc
2. Run - gpedit.msc
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
