huge injectors running in batch mode = bad mpg ?
Old Nov 14, 2005 | 05:28 PM
leecavturbo's Avatar
leecavturbo
Default huge injectors running in batch mode = bad mpg ?
running dta pro in batch mode and have horendous mpg when driving mega lightly, don't mind when thrashing it.
i have 525cc injectors running in batch mode, will changing to sequential dramatically improve mpg at light/cruising sensible driving ?
Old Nov 14, 2005 | 05:49 PM
ECU Monitor Enthusiast
Yes you will have bad fuel consumption.
Doesnt make much difference when under load though.
Usually batch injection triggers the injectors EVERY crank cycle if all 4 are
fired together or in alternate revolutions if triggered in pairs.
If you get the wrong pair in the wrong cycle that too can cause fuel drop out and cause high fuel consumption and bad idle.
Best use sequential (may need to double pulse width depending on configuation and ecu type etc...)
You will however need a phase/cam sensor so the ecu knows which
cycle the engine is on to do this properly.
(or some trick software )
Another issue when using EITHER modes is injector PHASING.
I.E WHEN the injector actually starts to open with respect to valve/crank position.
Large injectors will only be at there best is PHASED correctly.
Old Nov 14, 2005 | 06:33 PM
Mark Shead's Avatar
Mark Shead
Why would you be running it in batch fire you might as well have a MFI set up.
Mark
Old Nov 14, 2005 | 06:35 PM
SPi, thats the future
Old Nov 14, 2005 | 06:36 PM
On single cylinder engines
Old Nov 14, 2005 | 06:44 PM
leecavturbo
Mark
the vaux xe/let engine does not have anywhere to retrofit a cam sensor, it needs fabricating which is out of my range of skills/tools unless there's a purpose made add on that someone has created
Old Nov 14, 2005 | 06:51 PM
Mark Shead's Avatar
Mark Shead
leecavturbo
You can add a sensor to the cam wheel if you cant use the cam.
Mark
Old Nov 14, 2005 | 06:56 PM
Lee, there is a dizzy on the end of the engine with a hall sensor in it isnt there?
Failing that, just whack a drive on the front of one of the cam pulleys like a manta does
Old Nov 14, 2005 | 07:00 PM
Mark Shead's Avatar
Mark Shead
Forgot that that what the Autronic uses
Mark
Old Nov 14, 2005 | 07:18 PM
leecavturbo
yep i wired it up, but the dta needs to know the angle of that hall sensor from tdc or something like that
Old Nov 14, 2005 | 07:24 PM
leecavturbo
here. no-one knows the angle sbd or qed
Old Nov 14, 2005 | 10:35 PM
GARETH T's Avatar
GARETH T
measure the angle
Russ Hill
Aug 31, 2015 06:44 PM
Toe Knee
Aug 23, 2015 08:31 AM
The Enigma
13
Aug 20, 2015 09:38 PM
Neatrags
Aug 16, 2015 07:57 PM
ginger1979
Jul 31, 2015 09:56 PM
