ICE BLUE INJECTORS ( FLOW ) HOW MUCH MORE THAN GREENS?
Old Nov 13, 2005 | 09:48 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Default ICE BLUE INJECTORS ( FLOW ) HOW MUCH MORE THAN GREENS?
Just wondering how much more these flow than greens, i could have a chance of four, im changing from standard yellow ones and have a brand new set of greens, but if the blues flow more then i might do a deal to get them, any help apreciated
cheers
Old Nov 13, 2005 | 09:50 PM
gurnE's Avatar
gurnE
Light blues? Good for circa 400bhp
437 cc/min IIRC
Better spray pattern than greys apparently too
Old Nov 13, 2005 | 09:52 PM
NUTTIN RILLA
Excellent mate, do you think its worth my while then? i`ve heard the max boost you can run on greens is about 26psi, would i be safe to go more on the blues then?
Old Nov 13, 2005 | 09:53 PM
gurnE's Avatar
gurnE
Depends on the rest of your spec mate.
What turbo?
Old Nov 13, 2005 | 10:01 PM
NUTTIN RILLA
I`ve only got a t34, im just about finished my rebuild, low comp pistons 7-2-1 cr, rs 500 cooler, breather system, big filter, stainless exhaust, swirl pot, all samco`s, 044 pump, and my head has been buffed up a good bit, just the usual kind of stuff. i would like a reliable 350bhp, so hopefully my turbo holds on which is probably the next thing to change
Old Nov 13, 2005 | 10:03 PM
gurnE's Avatar
gurnE
Well, you could see 370-380ish on the light blues @ 28-30ish psi.
The greens will fuel to about 350-360 on standard fuel pressure so either run the greens flat out with no margin for error or use the light blues
Go for the blues imo
Old Nov 13, 2005 | 10:04 PM
NUTTIN RILLA
Thanks mate, my minds made up
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
