two questions
Old Nov 13, 2005 | 06:06 PM
rs cos's Avatar
rs cos
Default two questions
1st - when fitting an uprated intercooler on my esc cos i was just wandering what to use to connect the existing charge cooling pipes ?
2nd - anyone fitted a 50mm radtec rs 500 cooler do i have to make
a bracket to bolt it in where the standard rad bolts in ?
Old Nov 13, 2005 | 06:08 PM
Damo V's Avatar
Damo V
Pro alloy cooler fitted straight in and came with a "U" piece of pipe to bypass the old cooler... Or someone like Roose, will be able to make you a U silicone pipe
Old Nov 13, 2005 | 06:23 PM
rs cos's Avatar
rs cos
anyone got pics of there u bend? thanks damo
Old Nov 13, 2005 | 06:24 PM
Damo V's Avatar
Damo V
Its like a piece of copper pipe about 5 inches ong, bent in half... with ridges on either end
Old Nov 13, 2005 | 06:32 PM
Damo V's Avatar
Damo V
http://www.proalloy.co.uk/cgi-bin/si...14&id=proalloy
Old Nov 13, 2005 | 06:44 PM
rs cos's Avatar
rs cos
cheers damo ill order that in morning. quick question tho the brackets on that intercooler look like the same on my radtec, they come straight out at the side rite. if thats the case does it bolt into where the rad does and if so where does the standard rad bolt into so?
Old Nov 13, 2005 | 06:47 PM
Damo V's Avatar
Damo V
I bolted my cooler to std rad supports then used the brackets supplied with the pro alloy cooler to bolt rad up... hang on ill find pics
Old Nov 13, 2005 | 06:49 PM
Damo V's Avatar
Damo V
I lied.. here you go
BTW the horrible manky brown stuff is waxoyl
Old Nov 13, 2005 | 06:58 PM
rs cos's Avatar
rs cos
damo ur a star thanks for the help
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
