exhaust vs inlet cams
Nov 13, 2005 | 02:17 PM
what's the difference between exhaust and inlet cams,how can be they recognized?? Is to possible to use a inlet cam on the exhaust side??
Nov 13, 2005 | 02:19 PM
No, you can't swap them round
One of the cams has a line around the carriers. The inlet I think, I'm sure someone else will confirm
the inlet cam has groves on its bearing surfaces
Nov 13, 2005 | 02:31 PM
why can't they be swapped over???
Nov 13, 2005 | 02:34 PM
i've known a few tuners that HAVE used an exhaust cam on the inlet side on a cossie
Surely the timing/duration/overlap etc would be completely different on the inlet compared to the exhaust?
Nov 13, 2005 | 02:39 PM
timing and therefor overlap can be cahnged though with a set of verniers or other methods
Nov 13, 2005 | 03:04 PM
So can they be swapped
Nov 13, 2005 | 03:40 PM
Quote:
yes but i think you have to time that cam 180 degs opposite.
Nov 13, 2005 | 03:55 PM
The guy who reconned Daveyboy's head put the cams round the wrong way round.
When we put the cambelt on and timed it up to TDC in the usual way, we got valve piston contact.
As suggested, it would be 180 degrees out would it not?
Nov 13, 2005 | 03:59 PM
The cams are identical bar the groove on the inlet cam!....Pon if you have valve contact you timed it up wrong
The woodruff key need to be opposie each other...so yes you are correct Pon 180 out
From what i remember!!!
Nov 13, 2005 | 04:03 PM
Yeah, that's what I meant Phil - wouldn't time up with the cam pointers facing each other.
Nov 13, 2005 | 04:07 PM
Both pointers needed to face away from each other as opposed to pointing at each other to get correct timing
Nov 13, 2005 | 04:13 PM
Quote:
all you have done by doing this is put the crank 360 degrees out, so just the engine phase is out of position
Nov 13, 2005 | 04:16 PM
No gareth you put the cams in like i said to begin with if you KNOW they are the wrong way round
Cosnada
Jan 7, 2016 05:30 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
A.t.p
Sep 29, 2015 05:04 PM
