Misfire Help!!! :(
Hi guys, wondering if anyone can help....
My Fiesta (1.25 Zetec), it started about 3miles away from home, just a slight misfire at about 3000rpm, it also stutters when pulling away at about 1200rpm
Phil has taken the plugs out and found No4 to be all coked up, cleaned it up, refitted closing the gap slightly and no difference, replaced the plug for another, no luck, still there.
Guessing its probably the lead? Its coilpack, and the missfire is only affecting one cylinder, so I am guessing the coilpack is fine, as it'd affect two if it was broken?
Any help appreciated, thanks guys
Try swapping the leads over to see if the Misfire follows where you put the 'Suspect' lead. Obviously make sure you swap both ends!!
e.g. If the Misfire is one number 4 Cylinder, try putting that lead on Cylinder 3 and the lead from Cylinder 3 on Cylinder 4.
Also, I am fairly sure that the Coilpack could still drop one Cylinder.
Changed leads and plugs today and its still the same, will get a coilpack tommorow and give it a try.
Car is still very drivable with it missing, bit of a pain though, hopefully its just a coilpack and nothing more serious
CabrioTurbo
Aug 1, 2015 11:04 AM
