FAO Secs or anyone who would know about water injection
Nov 11, 2005 | 06:52 PM
Apparently this is a water injection add on to an L6 ECU, just wondering how it works etc etc
Nov 11, 2005 | 08:15 PM
Nov 11, 2005 | 09:48 PM
SECS??
Nov 11, 2005 | 11:02 PM
looks like its taking an input from the air charge sensor,,, and putting an output on at set-point
how technical do you want?
Nov 11, 2005 | 11:37 PM
Nov 11, 2005 | 11:39 PM
Nov 12, 2005 | 06:53 AM
inside the sleeve is just another small circuit board, I was told when I got the ecu that secs would know about it.
all I want to know is how it works and how to wire it up?
Nov 12, 2005 | 10:10 AM
I would sell it and use a pectel board so you can adjust the temps and pressure that the WI will come on at.
Nov 12, 2005 | 11:32 AM
Quote:
how do you know its not got little pots inside to adjust things like this ?
if simon built the board im sure he will have made it configurable
Nov 12, 2005 | 05:52 PM
Yes i imagine you can adjust the settings but i would prefer to adjust them via the ECU instead of a standalone type system.
This way you can set it in the map to do other things not just Temp or Pressure related.
Regards
Nov 14, 2005 | 05:32 PM
I just wanted to know if it was worth using seeing as it was in there, someone must know????
Nov 14, 2005 | 05:36 PM
I built that !
Nov 14, 2005 | 05:38 PM
Quote:
Originally Posted by SECS
I built that !
WELL THAT DOESNT REALLY HELP THE BLOKE DOES IT
Nov 14, 2005 | 05:40 PM
Thanks for pointing the obvious out Dave you COOOOOOOOOONT
It is a water injection add on controller, preset to 20 psi boost and 40 degrees charge air temperature.
It is NOT mapped but an independant controller board I designed.
Hope that helps
Nov 14, 2005 | 05:42 PM
do not attach a water feed to it
Nov 14, 2005 | 05:45 PM
b19bal Good advice
Just PMed you avengerpenguin
Nov 14, 2005 | 05:46 PM
Simon, that does help how easy is it to complete the system. What bits would I need???
Nov 14, 2005 | 05:50 PM
Nov 14, 2005 | 06:18 PM
Next question, where can I get a pump and nozzle to make a system
Nov 14, 2005 | 06:20 PM
That ecu looks familiar
Nov 14, 2005 | 06:26 PM
Nov 14, 2005 | 06:47 PM
It should do Lee, lol
Thought I would investiagte it further now that the cossie is stripped.
Thanks Simon
Nov 14, 2005 | 07:31 PM
give me ur new pda and i'll come fit it for ya!
might not work, or indeed do anything, but i'll fit it
Nov 14, 2005 | 11:22 PM
Nov 15, 2005 | 07:22 AM
I also sell the WI pumps
. See my website.....
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
