series 1 doesnt like starting
Old Nov 10, 2005 | 06:25 PM
stusfesta's Avatar
stusfesta
Default series 1 doesnt like starting
hi, when i start my rs from cold it just splutters the first couple of tries like its flooding? is there a nack to startin them?! ive only just bought it
Old Nov 10, 2005 | 07:08 PM
andyt's Avatar
andyt
sounds like it needs set up mate or your cold start valve is fooked
Old Nov 10, 2005 | 07:36 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
disconnect the blue plug under neathe the inlet plenum and see how it goes then, (cold start valve)
Old Nov 10, 2005 | 09:54 PM
addiction's Avatar
addiction
as vroooom ptssssh says above,it usually does the trick
Old Nov 10, 2005 | 09:58 PM
stusfesta's Avatar
stusfesta
ahh ok ile give it a try in the mornin cheers guys
Old Nov 11, 2005 | 01:33 PM
MikeyXR2i's Avatar
MikeyXR2i
Check there are no little fuel leaks around metering head and electromagnetic pressure actuator, small leaks here will let the fuel pressure drop off and the car won't like starting from first thing.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
gingeRS
Sep 4, 2015 06:29 PM
turbowag
Sep 3, 2015 08:07 AM
