Info n a lil problem
Old Nov 10, 2005 | 01:02 PM
rs_daz's Avatar
rs_daz
Default Info n a lil problem
Might pick up a new actuator soon . theres a -31 on it at the mo which is a few years old .but whats the difference between a -34 and -31? i run about 22psi..
some days my car boosts up over the set 22 psi limit and other days below it..this is mainly day n night but thought the blitz boost controller would help steady the boost?
Also not sure if its related but when i do a launch and shift it into 2nd the car bogs i.e no power n till i shut off and then plant my foot again .not sure but i recon the boost pipe to metering head colapses :g: again a few yrs old on them..
Whats plps thoughts
Old Nov 10, 2005 | 02:21 PM
ze-vh phil's Avatar
ze-vh phil
have you got silicon boost hoses?
if not get some!!!
the normal ones go soggy and collaps.
could solve your problam.
Old Nov 10, 2005 | 05:02 PM
rs_daz's Avatar
rs_daz
I have samcos and there about 3yrs old
Old Nov 10, 2005 | 05:12 PM
T28 RST's Avatar
T28 RST
Ok then
Mine are 4 years old and they are still like new
Old Nov 10, 2005 | 05:16 PM
Oranoco's Avatar
Oranoco
My Samco's are ageing now but are still fine
Old Nov 10, 2005 | 05:18 PM
rs_daz's Avatar
rs_daz
Could it be that i have a bigger turbo fitted now so the bottom pipe to meteringhead is more kinked as to say a std turbo?
Old Nov 10, 2005 | 05:24 PM
T28 RST's Avatar
T28 RST
Ok then
Cant you trim a bit off the hose so it sits better
Old Nov 11, 2005 | 04:15 PM
rs_daz's Avatar
rs_daz
I did that but doesnt seem to of helped.
liamT74
Sep 23, 2015 10:24 PM
Del gsxr
Sep 19, 2015 05:53 PM
Fordmad!
Shows & Track Days
Sep 15, 2015 12:26 PM
Flateric_2002
Sep 15, 2015 08:41 AM
focus2351
Sep 9, 2015 09:33 PM
