im just about to go buy oil but.......
Old Nov 9, 2005 | 11:51 AM
Combi_Chris's Avatar
Combi_Chris
Default im just about to go buy oil but.......
what is the correct viscosity ???
im about to go buy some mobil one, but i have no clue what one to get ??
i know there are better oils around but i have 3 days off from work and wanna get it done asap .
what is the correct mobil one oil i need ? for my rs turbo
Old Nov 9, 2005 | 11:52 AM
Oranoco's Avatar
Oranoco
If you are buying Mobil 1 it is the Motorsport one you want (15-50)
Old Nov 9, 2005 | 11:59 AM
Combi_Chris
ok thanks bud
Old Nov 9, 2005 | 12:01 PM
mantamark's Avatar
mantamark
i thought fully synth would be too thin for an old turbo engine?
I am changing mine to duckhams qxr semi, might help with the tapping too
Old Nov 9, 2005 | 12:12 PM
Oranoco's Avatar
Oranoco
That's why you use the 15-50 and not the 0-40 stuff.
Old Nov 9, 2005 | 12:17 PM
Combi_Chris
my cars got a new engine, only done 1800 miles, the car itself is old, but the engine is quite new , so ill do what oranoco has suggested
Old Nov 9, 2005 | 12:18 PM
mantamark's Avatar
mantamark
ahhh, i though all mobil 1 was fully synth
Old Nov 9, 2005 | 01:15 PM
Linsay's Avatar
Linsay
seems to be good stuff my old engine was still running well at 180'000 miles with it and am running my new one with it to
Think i might stock up in summer tho, as you can get it quite cheap at the shows and have had to change it twice in the last 4000 miles
Old Nov 9, 2005 | 01:38 PM
Combi_Chris
mind you......i do need to get a new sump and gasket , so when i do that im gonna see oilman for something better............
Old Nov 9, 2005 | 02:52 PM
Rallyesport's Avatar
Rallyesport
Mineral and Semi is not as good as fully. The only reason to buy semi is to save money.
Old Nov 9, 2005 | 02:53 PM
Combi_Chris
so your saying i should buy what exactly ? ?
Old Nov 9, 2005 | 03:16 PM
Oranoco's Avatar
Oranoco
Mobil 1 is fully synthetic
Old Nov 9, 2005 | 03:18 PM
Combi_Chris
thats what i thought, whats this guy talking about , is it just another sweeping statement i wonder ??
Old Nov 9, 2005 | 03:53 PM
addiction's Avatar
addiction
should allways put fully synthetic oil in her!!!
Old Nov 9, 2005 | 06:28 PM
Micky's Avatar
Micky
I've used both 15-50 and 0-40 Mobil 1 in my engine and have'nt noticed any difference.Always changed the oil at 3,000 miles or once a year now ,as its trackdays only with the car now.Regards Micky
Old Nov 9, 2005 | 07:47 PM
mantamark's Avatar
mantamark
I just figured, if ford didnt put fully synth in, why put it in now?
Old Nov 9, 2005 | 08:18 PM
CRASH n BURN's Avatar
CRASH n BURN
Im using 5-50 Mobile 1, Porshe std (semi synt.). Its a verry good oil if you got a heavy foot, and its allso recomended by Mobil 1.
Old Nov 9, 2005 | 08:39 PM
Combi_Chris
look ive got the oil, i dont want an oil war, lol
Old Nov 9, 2005 | 09:57 PM
faz10's Avatar
faz10
whats the differnce between castrol rs fully synthetic or mobile full synthectic...
Old Nov 9, 2005 | 10:53 PM
Rick's Avatar
Rick
Ive never read so much shit in my life!
I really can't be arsed with a lecture on oils, what their purpose is, and how they work.... We've got our resident Oil salesman for that....
If you want the best oil for your RST: In the winter, if u do a lot of cold starts, a thin fully synthetic is v good, such as mobil 0W 40. It gives better cold start protection than the thicker oils. Mobil 15W 50 motorsport, Valvoilie racing 5W 50, and my personal favourite, Millers CFS 10W60 are all excellent oils.
Old Nov 9, 2005 | 10:54 PM
Rick's Avatar
Rick
Castrol RS is not a fully synthetic oil in the true sense.
Old Nov 10, 2005 | 11:06 AM
Rallyesport
I want what's best for my car, Ford on the other hand want what's good enough so they can save money.
Old Nov 10, 2005 | 11:44 AM
mantamark's Avatar
mantamark
Fair enough, i was only giving an opinion, everyone having a go
Old Nov 10, 2005 | 08:37 PM
Rick's Avatar
Rick
The other thing is, when the RS was about, the availability of fully synthetics was not as great.
Old Nov 11, 2005 | 11:55 AM
oilman's Avatar
oilman
Wooooooooooooo.......................Hold on!
Lets start by looking at the correct oil to use instead of opinions, we can debate the brand once the correct viscosity is determined!
What year and model is the car and is it modded?
Do you do track days or is it a road car?
Simon
Old Nov 11, 2005 | 03:13 PM
mantamark's Avatar
mantamark
Hows about mine then, 140bhp s2, exhaust, panel filter, 10psi.
road car only.
do around 800 miles per month i think.
Old Nov 11, 2005 | 04:36 PM
oilman's Avatar
oilman
I would use a decent 5w-40.
Simon
Old Nov 11, 2005 | 04:44 PM
Combi_Chris
its a rebuilt 1600 escort turbo with low comp pistons stg 3 head t3 hybrid , running only 17 psi boost as its my daily driveronce its been back on the rollers and set up for a bit more power and higher revs, then i will come see you , but as the stuff i had in there was poo and old i just used the 15/50 as a quick fix, in january i think ill be ok to get her set up and then change the oil again
the cars only done 1500 miles also , i wish you had spoke sooner, lol
Old Nov 11, 2005 | 04:52 PM
antony215's Avatar
antony215
Escort Rs Turbo
Thats what i use in mine
Old Nov 11, 2005 | 05:04 PM
oilman's Avatar
oilman
I'm always here but best to PM or email me.
Simon
Old Nov 11, 2005 | 08:12 PM
andre_k's Avatar
andre_k
i use fully sin 5w-40 same spec as mantamark
Old Nov 11, 2005 | 09:11 PM
oilman's Avatar
oilman
That's fine, just use a decent one.
Simon
Old Nov 12, 2005 | 04:52 PM
Gadget's Avatar
Gadget
Spanner monkey
mr Oilman, how good is fully synthetic 10w 40? Please??
cheers, Gary
Old Nov 12, 2005 | 09:01 PM
Combi_Chris
cheers, Gary
i would guess it depends in what application ? ie , car , level of tuning, driving style .
Old Nov 12, 2005 | 09:14 PM
Rick's Avatar
Rick
You would not beleive the intricasies of this subject. For instance, the "10W" of a 10W 50 has a different viscostity to the "10W" of a 10W 60.
In practice, with modern oils it is difficult to really get it wrong.
My (educated ) opinion:
Lots of cold start winter driving - 0W 40.
General all purpose - 5W 40/10W 50
Hard use, not too many cold starts, especially for engines with large clearances, 10W 60 (millers CFS is the best i have found)
Rick.
Old Nov 12, 2005 | 10:19 PM
oilman's Avatar
oilman
Rick.
Im sorry but a 10w is a 10w and it has to be no more than a certain viscosity at -30degC (6600cp).
What is different is that a 40, 50 or 60 is a different viscosity measured at 100degC.
5w is better than 10w for cold start etc.
Multigrades
DegC...............0...............10............4 0..............100
0W/20............329............181...........46..... ..........9..
5W/40............811............421...........92..... .........14..
10W/50..........1039...........539..........117....... ......18..
15W/50..........1376...........675..........130....... ......18..
20W/50..........2305..........1015..........148....... ......18..
The "w" number is measured differently to the sae number (second/larger one).
0w is fine but slightly overkill in UK climate.
Simon
Old Nov 12, 2005 | 10:22 PM
oilman's Avatar
oilman
cheers, Gary
It's fine viscosity wise but quality varies dependent on brand etc.
A top one quality-wise is this one:
http://www.opieoils.co.uk/pdfs/MOTUL...9-%28GB%29.pdf
Simon
Old Nov 12, 2005 | 10:48 PM
Rick's Avatar
Rick
oilman
What units is that table in on the X axis?
Old Nov 12, 2005 | 11:49 PM
oilman's Avatar
oilman
Centistokes
Simon
Old Nov 13, 2005 | 12:05 AM
bassboy's Avatar
bassboy
oilman what would you recommend on a standard RST (bar air filter, exhaust and 9psi boost) with a fair few miles under its belt - 100k without a rebuild but going strong...
thanx
bassboy
