S2 ECU's?
Old Jul 8, 2004 | 03:59 PM
Paddy's Avatar
Paddy
Legend
Default S2 ECU's?
My ECU has a Heart, Triangle [does everyone else call these diamonds?], Hash on a sticker on it.
Without getting too technical:
Why do some have colours on the front instead of the hearts, triangle stuff?
Which colours, if any, correspond to mine?
What are the major differences between those with different colours/shapes?
Thanks!
Old Jul 8, 2004 | 04:00 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I think you will find that the one with the Heart Triangle Hash is a later replacement ECU.
Old Jul 8, 2004 | 04:02 PM
Paddy's Avatar
Paddy
Legend
So what should be on an 88 spec car?
Old Jul 8, 2004 | 04:05 PM
Doug's Avatar
Doug
S1 blue red blue (non knock sensor)
S2 early blue red white
S2 mid blue red black
S2 90 spec heart triangle hash
Old Jul 8, 2004 | 04:08 PM
flashpoint's Avatar
flashpoint
Hear
90 spec ecu
Steve
Old Jul 8, 2004 | 04:09 PM
Paddy's Avatar
Paddy
Legend
Steve m8, should mine have that ecu on it then? IT got the 90 spec one? Christ, I'm worse at electrics than I am anything mechanical and I'mm fooking rubbish at that....
Old Jul 8, 2004 | 04:15 PM
flashpoint's Avatar
flashpoint
Sounds as if it has been replaced at some time, it should run ok with it
May be the car was chipped before you bought it and the ecu was swapped out for a stranded one, that may explaine the problem you had with the boost cut out
Steve
Old Jul 8, 2004 | 04:18 PM
Paddy's Avatar
Paddy
Legend
I am considering swapping the wheels for a can of petrol and a box of matches to get rid of the rest of the bloody car....
Old Jul 8, 2004 | 04:20 PM
flashpoint's Avatar
flashpoint
Old Jul 8, 2004 | 04:24 PM
CabrioTurbo's Avatar
CabrioTurbo
as above the ecu you have is a later 90 spec one.
The only problem i could see this causing is if your older car doesnt have the knock sensor wiring.. as this should really be plugged into the ecu you have.. if you do have all the knock sensor stuff then i cant see a problem.
CheeRS
Phil
Old Jul 8, 2004 | 04:55 PM
flashpoint's Avatar
flashpoint
If I remember correctly paddy's car has a knock sensor, but at the kind of low boost levels he is running det is least of the problems
Steve
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
