Alloy radiator ( quickie )
It depends who made it.
On the Radtec ones the top rail is different - it doesn't have the mounts for the standard intercooler.
Also the height is different as the Escos ones mount on little stands and the Saff and 3DR ones mount directly to the chassis rails on rubbers.
Not sure about other makes. I think Pro Alloy do their own mounting brackets to mount them together and then onto the car.
HTH
Cheers,
Daniel
HTH
Cheers,
Daniel
I think you might be a little confused -
the 2wd has the thick pipe going to the water pump and the 4wd has the thick pipe going to the thermostate housing so the hoses are different not the rads.
cheers
Daniel
miss read your answer correct the pipes are different
cheers
Daniel
