charging fault/altinator
Old Nov 6, 2005 | 07:00 AM
JayRS2000's Avatar
JayRS2000
Default charging fault/altinator
what can i do next??
im having trouble at the mo with the car it seems now its due to ignition and no spark ive now bought new sparks new leads new coil dispritor rotor arm theres no spark from the sparks and theres a 12v cummin from the ignition coil so im stuck to where this problem is????
theres power going in to the coil but none cummin out and the coil cant be at fualt is brand new ???
also the cars running a s1 ecu is this anything to do with it?
would a new ecu be the next step
anyhelp would be sweet cheers jay
Old Nov 6, 2005 | 11:23 AM
antony215's Avatar
antony215
Escort Rs Turbo
Try changing the distributor i had the same problem with mine had no spark to the plugs changed the distributor and it fired up stright away it's a common problem on the rs turbo's
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
