fanny
Old Nov 5, 2005 | 05:52 PM
cossiematt's Avatar
cossiematt
Default fanny
how can i get the fan on my series one to cut in earlier???
it doesn't cut in till almost at the red at the mo
cheers
Old Nov 5, 2005 | 06:43 PM
Sideways_Sierra's Avatar
Sideways_Sierra
get a thermostat which has a lower temperature range.
i.e. a lower one than what you have now.
the lower the temp. the earlier it kicks in
Old Nov 5, 2005 | 06:50 PM
haz87's Avatar
haz87
or fit an override switch in
Old Nov 5, 2005 | 06:57 PM
Jim Galbally's Avatar
Jim Galbally
a THERMOSTAT is NOT the same as a fan switch!
and yes get yourself a nice shiny new fan switch, less than 20quid from ford (you can use a cossie on whichj i think is a few degrees lower if you like)
also your gauge is probably inaccurate aswell
Old Nov 5, 2005 | 07:00 PM
kevandalice's Avatar
kevandalice
how will changing the thermostat make the fan cut in earlier?
all that will do is shortly prolong the time it take to get to said temp.
what you need is a fan switch that cuts in at a lower temp or, as previously mentioned, an override switch
Old Nov 5, 2005 | 07:01 PM
kevandalice
jim beat me to it!!
Old Nov 5, 2005 | 07:02 PM
AJC's Avatar
AJC
low temp stat opens at lower temps
Old Nov 5, 2005 | 08:40 PM
cossiematt's Avatar
cossiematt
if i get a lower temp thermostat it won't alter when the fan comes in will it?!
all it will do is take longer to get up the current fan cutting in temp won't it?
i'd like the fan to cut in earlier if possible
Old Nov 5, 2005 | 08:49 PM
kevandalice
then you will need a different switch that switches at a lower temp
or
a manual override switch (wire in parallel with fan switch)
Old Nov 5, 2005 | 09:28 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
ive got a (brown?) XR2 fan switch and on my series 1 it kicks the fan in bang on the first quarter line, bit too early maybe but will do for when i get a nice big shiny pro alloy or GRS cooler
Old Nov 5, 2005 | 10:17 PM
DazC's Avatar
DazC
What matters is the temp it kicks in at, not where the needle is pointing on the (inaccurate) gauge!
Old Nov 5, 2005 | 10:53 PM
vroooom ptssssh
It Wasnt Me!
Very true darren, very true.
Old Nov 6, 2005 | 02:20 AM
bigal1978's Avatar
bigal1978
same as him m8 when i had an s2 just went to local motor factors got the switch that cut in the lowest never had any probs
Lee Reynolds
85
Aug 10, 2015 05:56 PM
Westy
20
Feb 27, 2009 05:05 PM
Oranoco
12
May 27, 2006 06:11 PM
