NEED RAPID HELP!!!
Old Nov 5, 2005 | 04:21 PM
Matt_B's Avatar
Matt_B
Default NEED RAPID HELP!!!
Just fitted new discs and pads to my ERST, they are black diamond cossie discs and rst pads. They work great and have got rid of my wheel wobble but when i put the car on half lock left or right they seem to catch slightly. Anyone got any idea's??????
Old Nov 5, 2005 | 04:39 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
wheel wobble thats nothing to do with your pads and discs thats the wheel bearing needing renewed or tightened!! (big nut in the middle of the disc)
new pads and discs you'll probably hear rubbing slightly when cornering because the gaps are so little, wait a few hundred miles and it'll be gone as the gaps between pads and discs enlarge.
Old Nov 5, 2005 | 04:41 PM
Dan's Avatar
Dan
Wheels might be out of balance aswell?
Old Nov 5, 2005 | 04:44 PM
Matt_B's Avatar
Matt_B
Def discs, the wobble has totally gone now i've changed them.
The wheels were the first thing i changed and made no difference.
Is there any adjustment on the conversion plates cos it is a real loud grinding noise not the usual light rubbing
Old Nov 5, 2005 | 11:35 PM
vroooom ptssssh
It Wasnt Me!
did you fit the plate on the front or the back of the hub?
pics?
Old Nov 6, 2005 | 12:03 PM
Matt_B's Avatar
Matt_B
There was a slight bit of adjustment in the conversion plate, I've just adjusted it in the PISSING RAIN and now everything is.....
Cheers for your help and advice
Old Nov 6, 2005 | 05:22 PM
vroooom ptssssh
It Wasnt Me!
Old Nov 6, 2005 | 05:54 PM
adamS2RST's Avatar
adamS2RST
Default Re: NEED RAPID HELP!!!
Told ya that would the the problem, I think u refer to 'brake judder' so Dave knows
Old Nov 7, 2005 | 08:22 PM
ze-vh phil's Avatar
ze-vh phil
you need to grind some of the caliper away mate, i had the same problem, the disc only just fits in the caliper, take out about 2mm ether side of the disc, don't work it won't weaken the caliper.
Old Nov 8, 2005 | 11:56 AM
Matt_B's Avatar
Matt_B
Grind metal off the caliper or off the slider/ pad holder thing??? Sorry for the random description.
Wheel wobble is still fucking there, It has to be a wheel bearing surely???
Old Nov 8, 2005 | 12:01 PM
RS_JAY's Avatar
RS_JAY
When the discs were off, did you notice any play in the hub at all??
Old Nov 8, 2005 | 05:12 PM
Matt_B's Avatar
Matt_B
Didn't really have a proper look but while the wheel was on and it was jacked up I checked for play and it seemed fine
col93saphcos
Aug 7, 2015 03:21 PM
The Rapid 1
14
Aug 29, 2005 03:13 PM
The Rapid 1
38
Jul 9, 2005 02:27 PM
The Rapid 1
15
Mar 13, 2005 07:40 AM
The Rapid 1
55
Feb 21, 2005 06:38 PM
