How much Boost?
Old Nov 5, 2005 | 12:24 AM
MK5RST's Avatar
MK5RST
Default How much Boost?
On an escort rs turbo with std internals, front mount cooler and a T3 with a 360 thrust bearing? std cam, std bore exhaust with 1 box, is it safe for 17psi?
Old Nov 5, 2005 | 02:26 AM
mrviper's Avatar
mrviper
take it somewhere to be set up for a chip and bar of boost
Old Nov 5, 2005 | 02:34 AM
GARETH T's Avatar
GARETH T
nothing safe unless tested
Old Nov 5, 2005 | 07:57 AM
Paddy's Avatar
Paddy
Legend
yeah it'll be fine
Do what they said, get it set up somewhere
Karl Norris pushes his stage 1 to around 17 psi with a front mount have a look on his website it explains it better
Old Nov 5, 2005 | 08:46 AM
ballin's Avatar
ballin
engines more than good for 17psi standard mate, as long as its in good nick!
Old Nov 5, 2005 | 09:49 AM
mattbibs's Avatar
mattbibs
my mates tuner told him no more than 16 on standard internals or it'll start to det. low comp pistons together with other mods are needed if you want to take it much further.
Old Nov 5, 2005 | 10:07 AM
Oranoco's Avatar
Oranoco
My last engine was standard internals and that was run at 17psi. Only failed thanks to a poxy valve sheering at the collet and colliding with the pistons
Mind you had it not failed I wouldn't have built the engine it now has
Old Nov 5, 2005 | 10:22 AM
MK5RST's Avatar
MK5RST
Ok, ive got a chip and a turbo with a 360 bearing so the turbo is upto the job, just wanted to know what boost its safe to run, its getting setup next saturday on the rollers
Old Nov 5, 2005 | 10:29 AM
big_wig_074's Avatar
big_wig_074
you got the ecu then fella?
Old Nov 5, 2005 | 01:25 PM
xr-stu's Avatar
xr-stu
a chap on here runs 24psi peak on his xr2 turbo, std internals (worked head and cam though) on a 2wd cossie cooler. setup by karl at NMS.
goes alright
Old Nov 6, 2005 | 10:34 PM
MK5RST's Avatar
MK5RST
yeah, got the ecu big wig , didnt realise u was on here
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
