Has anyone tried designing a turbo that doesn't.....
..fucking blow up!?
Surely in this day and age we should be making turbos that are maintenance free and last a damn sight longer than they do currently
Yeah, but i didn't mean manufacturere standard
Why can't i run 200psi on a T25! Its just not on!
Seriously though, just looking into getting a hybrid and wanna wind the boost up a tad, but am worried it might blow.
if everything i spec'ed right and maintained there is no need to worry about turbos blowing
turbos are great/clever/simple ides,,, the problem lies in monkeys who dont know what they are doing normally
why will an engine designed to rev to 6k not rev to 10k without blowing up,you would have thought this day in age they could
Run one at its designed boost and give it all it needs ie good pressure,clean feed and good return and it will run for years,in some cases outlast the engine
A 270 degree bearing is officially only rated to around 12psi (depending on manufacturer) yet in the modding world many dont still run within these limits
JK12
33
Apr 26, 2021 12:09 PM
