PACE Chargecooler, is it any good?
Old Nov 4, 2005 | 08:33 PM
GT2's Avatar
GT2
Default PACE Chargecooler, is it any good?
At lowering inlet temp at slow speeds and not restricting flow at higher boost?
Old Nov 4, 2005 | 09:49 PM
GT2's Avatar
GT2
up
Old Nov 4, 2005 | 10:12 PM
andyhardy's Avatar
andyhardy
Depends on car really but I'd say no - heat soak from the engine bay heat will cause you big problems when running much more than standard boost.
Awaits aload of smart arses to talk crap about sticking air-conditioning refrigerators on them.
Buy a FMIC.
Andy
Old Nov 5, 2005 | 07:12 AM
Eagle's Avatar
Eagle
Super Moderator
as stated .. on driving you get to a water temperature saturation point .. the water can no longer be cooled by the rad for it ..
so you need a bigger rad that holds more water .. etc etc etc
they get hotter if not moving / slow speeds ...
had one on my sII .. worked really well in the colder weather .. summer was a waste of time tho .. got a grs fitted and never had any act issues.
and the fridge idea works .. i tried using 2 peltier devices on a metal container .. but once again you get to a point where even they can not cool the return water quickly enough.. did have an improved design but never the money to be able to test it
Old Nov 5, 2005 | 03:07 PM
RS220Turbo's Avatar
RS220Turbo
i had one on my S2 and my old Fiesta, and the temp never went above the half way mark, even when on the rag, i say go for it
Sunny
Old Nov 6, 2005 | 08:03 PM
GT2's Avatar
GT2
Anyone used it on a cossie?
Old Nov 6, 2005 | 08:07 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
They work a lot better if you put them on the hot side as a standard escort cossie cooler with a separate water reservoir.
As the chargecooler will only be bringing the temperatures down marginally letting the intercooler work a little bit better.
HTH.
Cheers,
Daniel
Old Nov 6, 2005 | 08:36 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Been running one for 7 years on my S1 - never had a problem and car pulls like a train no matter how warm it is.
I recommend them.
Old Nov 7, 2005 | 08:18 AM
AKRS1's Avatar
AKRS1
I thought they really worked really well up to the point when my act temperatures were going well high during the summer but that was only in slow moving traffic. Does anyone know if they require maintenance?
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
3doorcozmess
Sep 15, 2015 06:06 PM
markk
Sep 9, 2015 08:11 AM
cbminis
Sep 7, 2015 09:42 AM
turbowag
Sep 3, 2015 08:07 AM
