Group A coil
As you look at the coil with the pins facing you which is positive and which in negative ? And is the green wire + or - ? Ta in advance lads.
PassionFords Creator
Originally Posted by Bosch-Man
Stu....i made the same mistake...
DIY baby
DIY baby
KSA:
Look closely between the 2 terminals and you will see an embossed polarity label.
