Sorry for swearing, but anyone any good with Vauxhall engine
Old Nov 3, 2005 | 03:20 PM
G1EN's Avatar
G1EN
Default Sorry for swearing, but anyone any good with Vauxhall engine
as me dads got a 2.0 16v OMEGA (Automatic)
and when in drive mode it just cuts out, no warning or nothing. Its quite common and happens on most journeys.
It idles at 600 rpm, which i thnk is slightly low for a 2.0 litre motor, but could just be vauxhalls, i dont know.
but when your on the throttle, its fine, then when you come off the throttle to slow down, if your off the throttle for long enough it sometimes cuts out, but mainly when you come to a stand still.
any help would be appreciated.
Old Nov 3, 2005 | 03:23 PM
ICV maybe?
Air leak on the inlet between the AMM and the TB?
Old Nov 3, 2005 | 03:26 PM
G1EN's Avatar
G1EN
i was thinking ICV. but me dads caveleir did exactly the same, and now this omega does it.... could it just be bad luck. he he that the both ICV's are shitty...
what is the AMM and the TB. (sorry for being stupid)
Old Nov 3, 2005 | 03:31 PM
Graceland's Avatar
Graceland
Team HOTHOT!
AMM = Air Mass Meter
TB = Throttle Body
the bit between them - rubber pipe
Old Nov 3, 2005 | 03:32 PM
ballin's Avatar
ballin
ICV for sure mate, well known problem. take it off and clean it up with carb cleaner, and check the breathers while you're at it.
Old Nov 3, 2005 | 05:21 PM
G1EN's Avatar
G1EN
cheers fella's
Old Nov 3, 2005 | 05:37 PM
Normally if its ICV though on the vauxhall lumps (especially the C20XE) it results in the idle wnadering up and down a lot.
Like literally up to 3K, down to 500rpm, up to 3k, back down etc.
Old Nov 3, 2005 | 05:52 PM
ballin's Avatar
ballin
yeah but also can't seem to catch the revs coming up to junctions etc.
my old mans vectra used to stall at junctions, revs wondered about etc. etc.
put new breather pipes on and cleaned out the ICV and it was better, still dips a little but no stall. recently started to idle at 1500rpm again tho so did it again last weekend seemed to fix it.
apparantly its because the crankcase breather returns to the throttle housing and gunks it up.
Old Nov 3, 2005 | 05:56 PM
Danny boy's Avatar
Danny boy
x20xev could be several things mate is the engine management light on? either constant or intermitant,
suffer from idle control probs, there is a modified iac vale but when this is fitted u need to carry out a couple of mods to the breathing of the engine, and is a good idea to get the ecu updated to at this time, as youll be using tech 2 to adjust the tps,
but could be a sensor too poss crank or cam!
hope this helps
Old Nov 3, 2005 | 05:57 PM
G1EN's Avatar
G1EN
sweet. ill get on to that at the weekend then.... nice 1 chaps.
markk
Dec 2, 2021 06:59 PM
track.focus'd
Aug 12, 2015 05:53 PM
knight19770
Aug 4, 2015 12:36 PM
Old ford
Jul 31, 2015 06:50 AM
