20psi ??
When i accelerate, in 1st, 2nd, i hit 15psi, too risky pushing it over that, 3rd about 18psi and 4th, 5th i can boost to 20si?? Is that right? Ive got a standard intercooler, but its chipped. Could it just be my clutch slipping, broken boost gauge or it can reach that on standard intercooler. I thought the highest you can hit is 15psi.
The head gasket blew, but didnt bother me as i was stripping it soon. It lasted about 4 months with a bit of thrashing here and there. I just didnt know if you could hit 20psi with standard I/C.
Ta for the replys though.
mine is reaching 22psi at times then it boggs down othertimes, think its the actuator spring too week! if you had of adjusted your actuator i dont think the boost wouldnt reach that high?
Technical essay Archives
59
Nov 23, 2005 10:58 PM
Dont boot it in 3rd, 4th, or 5th till you get it sorted, weird how it rises SO much
