various cossie & rs turbo parts updated with pics
Old Oct 30, 2005 | 07:24 PM
GUZZLER's Avatar
GUZZLER
Default various cossie & rs turbo parts updated with pics
having a bit of a clear out in the shed & cupboard at home, found loads of stuff i have hoarded over the years!!!!! seeing as we don't have an escort turbo, 3 door or saff cossie anymore these parts are no longer much use to me, plus the space will be handy, as will the cash towards the escos rebuild
was going to put pictures up, but can't be bothered at the moment
anyway, i have a list of various parts, some are new, all second hand parts are as described, here go's, (click link fo pic)
escort rs turbo cold start valve, brand new & boxed £50
saff cosworth fuel cap, later style twist fit one, brand new £5
http://img.photobucket.com/albums/v2...afffuelcap.jpg
fiesta mk3 (turbo, xr2i etc) boot lock, brand new with 2 keys £10
http://img.photobucket.com/albums/v2...e/bootlock.jpg
genuine ford '909' group a clutch release bearings £20 each
'92 spec saff cossie 'sharktooth' or 'snowflake' wheel centre caps £10 pair
4x4 saff cosworth rev counter, brand new boxed £50
http://img.photobucket.com/albums/v2...ssie/tacho.jpg
4x4 cossie or big turbo escos throttle body, brand new boxed £75
as above but with tps & iscv, also brand new boxed £250ono
cam pulley, brand new, marked 'LA' finnis code 6087 222 £5
http://img.photobucket.com/albums/v2...sie/pulley.jpg
3 door cossie heater blower switch, brand new boxed £15
http://img.photobucket.com/albums/v2...owerswitch.jpg
3 bar map sensor, second hand, works fine £50
saff cossie heater resistor, new & boxed £10
4x4 saff of big turbo escos distributor cap, new boxed & genuine, £20
fiesta turbo arm rest/door pull in grey, n/s, brand new, small scratch hence £5
http://img.photobucket.com/albums/v2...fezarmrest.jpg
saff clear indicators, pair of, good condition £7.50 SOLD
S2 n/s clear indicator, bit tatty £2
ford plastic battery covers, to fit smaller batterys, £5 each
http://img.photobucket.com/albums/v2...tterycover.jpg
S2 metering head, fuel flap & pressure reg, worked when taken off car but been sat around for a few years, not sure if it will still work properly, hence £10
http://img.photobucket.com/albums/v2...ie/s2mhead.jpg
S2 inlet manifold with tps, aux air sensor, throttle body etc, had plenum polished but has now gone dull (but still smooth) £15
http://img.photobucket.com/albums/v2...ie/s2inlet.jpg
'88 spec seat parts, l/h bolster cover, centre back section & foam, centre lower section & foam, £10
saff front window switch coloum & both rear switches £5
http://img.photobucket.com/albums/v2...ffswitches.jpg
saff electric mirrors (covers painted magenta) with glass £20 pair
http://img.photobucket.com/albums/v2...affmirrors.jpg
S2 n/s head lamp, carrello, silver finish, new & boxed £15
http://img.photobucket.com/albums/v2...s2hlampnew.jpg
saff head lamp glasses, new boxed genuine ford £25 pair
saff head lamp glasses, second hand but ok, £5 pair
http://img.photobucket.com/albums/v2...e/saglassh.jpg
S2 head lamp covers, gen ford new & boxed £45
http://img.photobucket.com/albums/v2...lampcovers.jpg
S2 fuel hose, rear of pump to tank, new genuine ford £5
http://img.photobucket.com/albums/v2...s2fuelhose.jpg
4x4 saff cossie high pressure power steering hose, new genuine £40
http://img.photobucket.com/albums/v2...saffpshose.jpg
3 door cosworth tailgate decal, new genuine & boxed (RARE) offers
3 door cosworth tailgate lock solnoide, genuine, new & boxed £20
http://img.photobucket.com/albums/v2.../solenoide.jpg
escort cossie n/s hockey stick, genuine, still in ford wrapper £75
http://img.photobucket.com/albums/v2...scoshockey.jpg
2wd cosworth brake pads, genuine ford, new & boxed £30 SOLD
S1 genuine o/s side decal, new & boxed, missing the part for the wing, £5
pair of 3 door rear lamps & gaskets, all brand new genuine ford £150
ngk racing 9 iridium plugs (set of 4) new & boxed £50 SOLD
3 door o/s headlamp glass, gen ford, new & boxed £20
saff headlamp covers, were on car for 2 weeks, back in origional wrappers & box, £30
3 door rear panel, gen ford, new £75
3 door rear quarter, gen ford, new £150 SOLD
S2 fuel computer, new & boxed £20 (comes with s/h fuel flow sensorSOLD
theres some more bits, if i get the time to root through them i will add them, thanks for looking
also found,
italvolante steering wheel, cossie or escort turbo fitment, mint, £95
http://img.photobucket.com/albums/v2...alvolante2.jpg
fiesta turbo bonnet, brand new but damaged, could possibly repair or just use the vent recesses £15
powerflex wishbone bushes for mk 3 fiesta (rs turbo, xr2i ect) or mk 5 escort, brand new £40
http://img.photobucket.com/albums/v2...frstbushes.jpg
rs turbo S1/2 ramair induction kit, used, ok £15
http://img.photobucket.com/albums/v2.../ramairrst.jpg
boyracer exhaust, anodised red can with polished silver 4" tailpipe with heat effect, came off a S2 escort £30
mac audio 12" sub, 300w, brand new £50
saff cossie fog lamp bezels, new £25
http://img.photobucket.com/albums/v2...saffbezels.jpg
2wd cossie cooler, ok £25
http://img.photobucket.com/albums/v2...ER/cooler2.jpg
S2 rs turbo/xr3i ABS belts, 1 early type, 1 late type £5 each
escort RS Turbo amal valve, new & boxed, £25
http://img.photobucket.com/albums/v2...ossie/amal.jpg
also found,
2wd cosworth starter motor, brand new genuine Ford £60
cosworth cam cover with breather port welded in, freshly painted in green (like '92 spec saff) £65
http://img.photobucket.com/albums/v2...e/camcover.jpg
L8 ecu, green top, something wrong with the babyboard in it, but runs fine on another b/b/ i tried in it, hence £100
RS Turbo fan switch, new gen ford £5
http://img.photobucket.com/albums/v2.../fanswitch.jpg
2wd outer rear c.v. stub, brand new £20
http://img.photobucket.com/albums/v2...ossie/stub.jpg
RS Turbo rear wheel bearing, new gen ford £10
bailey dump valve, dv24 £20
saff wiper switch, new gen ford £15
Fiesta turbo big brake kit, hi-spec, 280mm disks & caliper spacers, brand new £125 prov. sold
http://img.photobucket.com/albums/v2.../285mmconv.jpg
2wd cosworth T5 5th gear, brand new gen Ford (& bearing) £60
http://img.photobucket.com/albums/v2...ie/5thgear.jpg
S2 fuel pump relay, new gen £15
http://img.photobucket.com/albums/v2...ie/s2relay.jpg
3 door grille seal, brand new £15 each
http://img.photobucket.com/albums/v2...grilleseal.jpg
escort cosworth radio, cd player, amp & lead £100
mk1, mk2 escort or mk 1 capri lower arms, new genuine ford £75 pair
escos/3 door fog lamps, new gen ford £50 pair
http://img.photobucket.com/albums/v2...e/foglamps.jpg
RS2002 mk5/6 fuel rail with injectors, new gen ford £80
http://img.photobucket.com/albums/v2...e/furlrail.jpg
mk5 escort headlamp protectors, new £20
mk4 fiesta headlamp protectors, new gen ford £20
mk3 fiesta headlamp protectors, new £25
Old Oct 30, 2005 | 07:36 PM
s1kid's Avatar
s1kid
Pm sent.
Old Oct 30, 2005 | 09:20 PM
Rick's Avatar
Rick
I'll have the fuel computer matey
Old Oct 31, 2005 | 10:53 AM
SamERST's Avatar
SamERST
Hi mate could you post some pics if these please "S2 head lamp covers, gen ford new & boxed £45"
Old Oct 31, 2005 | 11:18 AM
give me a shout Matt if there's anything there you think would benifit YVV.....been awhile since ive had to pay ya for something
Old Oct 31, 2005 | 11:40 AM
GUZZLER's Avatar
GUZZLER
Old Oct 31, 2005 | 11:41 AM
GUZZLER's Avatar
GUZZLER
Old Oct 31, 2005 | 08:56 PM
rauri's Avatar
rauri
up in smoke........
u have pm
Old Nov 6, 2005 | 09:09 PM
Rs Adz's Avatar
Rs Adz
how bad is the fiesta rs turbo bonnet mate and have u got any pics
Old Nov 7, 2005 | 05:01 PM
GUZZLER's Avatar
GUZZLER
not got a good pic of it, this is the only one i have at the moment.
Old Nov 7, 2005 | 05:14 PM
Rs Adz's Avatar
Rs Adz
hi sorry it might just be me but i carnt tell wots up with it is it dented i can see the scraches and wot lookes like a dent at the top of the pic left hand side can u get us some more pics 2 see wots up with it cheers
Billy_RS
16
Oct 11, 2025 09:41 PM
carlo
24
Oct 5, 2015 08:20 PM
muz
Aug 16, 2015 12:57 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
155lee
Aug 14, 2015 11:21 AM
