mad project idea V6 Escort
hi all as u can guess yep its a mad crazy but i like the sound of it and i need lots of help for starters does anyone know if it can be done or if someone have done it b4 wot im wantin to do is put a 2.8 or 2.9 v6 in to a mk5 escort its now got the cossie looks and just needs the get up and go everyone does the rst or the cossie engine but i want to do something else and wot better than the good old V6 if anyojne can help let me know cheers
Phill
Phill
Originally Posted by excursion
Many many years ago Ford themselves produced a one off V6 Mk 5 Escort. It was basically an Escort Cosworth shell, with the upper rear wing deleted, the front splitter removed, and a late spec bonnet with the oval grille. Under the bonnet was a 2.9 V6 24v Granada Cosworth lump. They opted for the 5-stud hubs from the Granada also, and fitted those 16" rims with the flat wide spokes.
If Ford can do it etc
Bit off the topic but here is one nice finnish taunus with boa engine (2.9 v6 24 cosworth with turbo and megasquirt). Car owner state that taunus has +400hv / ++500nm / ++250kmh. Here some nice video and pics
http://s103.photobucket.com/albums/m...current=23.flv
http://s103.photobucket.com/albums/m...gAnch=imgAnch1
http://i103.photobucket.com/albums/m...V6/6000rpm.jpg
so i guess its work nice also in escort
you could buy this as most of the works been done. would prob save you money in the long run?
http://cgi.ebay.co.uk/1993-FORD-ESCO...QQcmdZViewItem
Originally Posted by COSSIE CAL
seems pointless really,just shove a zvh or zetec in it then turbo it
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
