Rover M16 inlet on zetec engine with ofab/ofac guide
Old Oct 29, 2005 | 05:50 PM
Red16's Avatar
Red16
Default Rover M16 inlet on zetec engine with ofab/ofac guide
heres how the complete rover m16 inlet manifold looks
rover fuel rail modified by drilling and tapping 2 new holes to allow fitment of the fiesta turbo fuel pressure regulator
the old throttle body on the end of the rover plenum was cut off as in the below pic
idle speed control valve was fitted by drilling and tapping the necessary holes to allow it to screw onto the plenum, a spacer plate was needed to prevent the sensor plug fouling the plenum. a flange to suit the fiesta turbo throttle body was made, and welded onto the end of the open rover plenum chamber
rather than use an adaptor plate i cut the flange that bolts to the cylinder head off the rover inlet
and also cut the flange from a zetec manifold
then welded the two together, the injector ports needed a small amount of weld build up and then have it ground out inside the port
this face was the milled flat at work, this was necessary because when it was welded the flange wasnt bolted down to something solid so it warped and was no longer flat
heres the finished face, all nice and perfectly flat and smooth, it may not look it in the pic but it is 100% true
the finished manifold with all the ancillary's bolted on looks like this :Q
Old Oct 29, 2005 | 07:07 PM
GTechR's Avatar
GTechR
Top top work matey
Old Oct 29, 2005 | 08:01 PM
essexrsturbo's Avatar
essexrsturbo
dont tell me your running fiesta turbo management on your zetec!!
Old Oct 29, 2005 | 08:15 PM
Red16's Avatar
Red16
no im gonna go cossie or maybe aftermarket
Old Oct 29, 2005 | 10:24 PM
essexrsturbo
Old Oct 30, 2005 | 07:17 AM
Gadget's Avatar
Gadget
Spanner monkey
Why not??
If it's mapped properly, it's just as good!
JoeyBoyden
Jan 4, 2024 02:36 PM
Danielbetty
Aug 28, 2015 08:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
mattman1234
24
Aug 1, 2015 11:46 AM
