s1 ecu question...
a quick question regarding a s1 ecu..
the s1 i`ve got was running 6 psi standard boost..
now i would have thought that that would mean it`s not chipped..
anyway, havin a mess about with it yesterday and decided to test it with a bleed valve instead of the amal valve..
well took it out and was hitting around 12 psi.. so as i understand it wouldn`t hit that without a chipped ecu.
but the cluch is slipping like a gooden now
so is me ecu chipped???
paul.
may be usually 10psi PLUS, means chipped, but have spoken to some owners
who swear it is over 10, and not chipped, if you open up the silver
ecu you should be able to see a chip with company label on it
if chipped,
DAVE R
if chipped,
DAVE R
cheers for the replies..
will have to have a look at the ecu and open it up..
well would be a bonus if it is..
better got the old 4 paddle from me old s2 in there!!
What if the bleed valve he has fitted has been turned out, would that not increase the boost?
or does the chip limit the amount of boost you can run?
i am on 10psi, on a std ecu
well was out in it again last night...
clutch was slipping like buggery...
anyway when on boost it would just cut the boost so i`m gessing the ecu was cutting it as it`s overboosting..
so set to 8 psi.. no problems now
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
