Vibrating Clutch Pedal?
If i drive the car off boost, its fine, as soon as it starts to boost, the clutch pedal becomes possessed, it shakes like a mo fo, making the stalks, brake pedal & pretty much everything else vibrate.
If i put my foot down on the clutch, even a little, it will stop, but release it & off it goes again.
The pedal has been "rebushed" by prev owner, and there is a uprated clutch in there.
Hope someone can give me some ideas, as it really getting on my tits now
many thanks in advance.
Mark.
Mark.
so probs the clutch is fooked & thats why its vibrating?
the biting point is very low, mebbies 1 inch from the floor?
are they adjustable in the rst? or automatic?
cheers for the info
cheers for the info
is the spring in place?
If it is an AP clutch, it really should have the Mark 5 pedal conversion, as AP messed up the design of the release bearing. However, if done properly, the mk5 pedal conversion gives a really nice pick up.
hmmm, what is needed for this conversion?
roughly how much does it cost & how do i go about converting it?
cheers for the info Rick, you seem to answer all my questions
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
