focus speedo problem
Old Nov 25, 2003 | 01:48 AM
Default focus speedo problem
I have a T plate 1.6 zetec focus.I have an intermittent problem with the speedometer ie when im driving along the needle keeps jumping all over the place and also stopping completely.I say its an intermittent problem as it does not occur all the time but it is becoming a problem does anyone out there have any idea how i can rectify this problem just wondered if anyone could throw any light for me please.
Old Nov 25, 2003 | 07:49 PM
Doug's Avatar
Doug
It is one of two faults m8
Either clocks faulty or under your air box you will see two earths bolted to the inner wing remove clean and treat with terminal / grease spray and refitt but seperate them if not already done
Hope this helps Doug
Old Nov 28, 2003 | 11:04 AM
if the earths dont cure it mate, ive had alot of vss fcuking up, its in the diff casing with a rollpin holding it in. careful sum of them are seized in.
Old Nov 29, 2003 | 06:42 PM
Martini, Hello again you gave me the info on my speedo problem on the focus i took the two earths off from under the air filter box cleaned them up with a wire brush and reconnected them i didnt spray terminal grease on them but white grease does that matter.as you can tell im no mechanic but a normal guy who loves his motor and wants the problem sorted the problem is still occuring should i of taken the paint off where the earths are connected so they touch bare metal or is it cause i used white grease instead.Or is my speedo u/s.As for the vss in the diff case is that easy or a garage job.Like i said sorry to bother you again mate but i appreciate the help before. marki boy
Old Nov 30, 2003 | 07:36 PM
Could be the speed sensor in the gearbox, about £75.00 from Fords
Big Al
Old Dec 4, 2003 | 06:58 PM
L33 BYT's Avatar
L33 BYT
I'd just send it to the scrappers Marki boy.
Just joking bruv. U ok mate.
Old Dec 19, 2003 | 07:54 PM
I also have a Ford Focus 1.6 Zetec and a few days ago I noticed that my speedo wasnt working.
I have since made a booking with ford to get it checked out.
I shall post once I hear what they have to say about it.
Bryan
Old Dec 31, 2003 | 06:56 AM
Speed sensor! Does the speedo stay at nothing sometimes when driving? and if it is reading 0 and you stop does the engine cut out?
Old Jan 3, 2004 | 04:38 PM
sounds like uve got a idle control valve problem too matty
Old Jan 4, 2004 | 09:31 AM
No, Just speed sensor. Not had any problems since it has been sorted. The focus speed sensor doesnt just supply the speedo, it also gives info to the ECU for fuelling. When there is no signal from the speed sensor but the ECU is getting informtion from other sensors saying the car is running it gets confused and stalls.
Great thinking isn't it LOL
Old Jan 22, 2004 | 02:52 PM
jo90's Avatar
jo90
Ford, you have to love them
Old Jan 22, 2004 | 09:36 PM
st3v3's Avatar
st3v3
youre just trying to lose youre virginity in this forum arnt ya with all these posts i mean,lol
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Escortdriver1
Jul 31, 2015 02:36 PM
