Help Needed pics of roll cages in a cossie please
Old Oct 28, 2005 | 07:02 PM
Alan s1's Avatar
Alan s1
Default Help Needed pics of roll cages in a cossie please
I need pics of any 3 Doors And any saphs with roll cages asap They need to be pic from inside the car Please
As im have lots of problems with mine As i've seen 2 3 Doors with cages and there differnt to my cage i got for the saph cos My front bars come down behind the dash and not in front of the dash
Is there any differnts in them
Old Oct 28, 2005 | 07:34 PM
STUCOS's Avatar
STUCOS
Alan, saff cage from roll centre requires dash to be cut for front section to between dash and bulkhead,3 dr cage goed down front of dash
cheeRS stu
Old Oct 28, 2005 | 07:44 PM
Alan s1's Avatar
Alan s1
cheeRS stu
I see Mine had a safty devises sticker on it which had been painted over
I got my dash out ect but its not going to plan Its the front half that im having problems with ,
Whot the roof like on the saph cossie with out the head lining in ais it stuck in ect ??? or can i remove it with out any problems ???
As its Rely dirty anyway
Ps is anyone else having with the Emoticons(smilys ect ) there not working for me nore is the Quote button ????
Old Oct 28, 2005 | 07:47 PM
Micky's Avatar
Micky
Alan,as Stu says,just cut a bit out of youre dash.Your rollcage is designed to run tight to the A pillar so that it can be welded to the pillar using metal brace's,makes the whole shell alot stiffer.Look at any WRC or modern rally car and they all have youre type of cage.By the way,you dont have to weld the cage to the A pillar,as its a bit hard core for a road car.Regards Micky
Old Oct 28, 2005 | 07:56 PM
xr4x4rs's Avatar
xr4x4rs
this is mine
safety devices 6 point bolt in
same as a saf one even though its in a 5door
hope this helps
Old Oct 28, 2005 | 08:09 PM
warleydaddy's Avatar
warleydaddy
Theres mine...
Pete..
Old Oct 28, 2005 | 08:48 PM
Alan s1's Avatar
Alan s1
Right I got to have a look @ mine tomorrow AGAIN i can get the front half to sit right its like the front legs are to long And im trying to do it on my own as veryone is out when i need help
Can someone get a pic of one thats fits behind the dash Please
Ps if theres anyone near Reading or Oxford thats up for helpimg give me a shout PLEASE
Old Oct 28, 2005 | 08:52 PM
Alan s1's Avatar
Alan s1
This is my cage it had a mirror weld onto it as it was in some sort of stock/Banger racing car
That is now removed And im trying to fit it all and get it lined up right then remove it so Radders can Paint it for me
Old Oct 29, 2005 | 10:34 AM
RichardPON's Avatar
RichardPON
Mine's a welded in cage, so entirely different, but these pics might help:
Old Oct 29, 2005 | 10:36 AM
RichardPON's Avatar
RichardPON
Old Oct 29, 2005 | 12:31 PM
Alan s1's Avatar
Alan s1
Cool we got any more cages in saph's prefer bolt in but im so tempted to weld the bloody thing in Its just a case of painting the whole inside then
Ps can someone tell me how Easy it is to remove the head lining and does it leave any sticky glue ect on the roof when out
Old Oct 29, 2005 | 12:32 PM
Red16's Avatar
Red16
RichardPON you got an engine bay shot of your cage, showing it going to strut tops ?
Old Oct 29, 2005 | 02:00 PM
RichardPON's Avatar
RichardPON
Yes mate:
Old Oct 29, 2005 | 05:02 PM
Red16's Avatar
Red16
was curious as to the routing of the diagonals from bottom of A pillar to strut top, thanks for that
my cage should be delivered by back end of next week
Old Oct 29, 2005 | 06:32 PM
xr4x4rs's Avatar
xr4x4rs
there should be no or only a little bit og glue mate
its held up by one sticky pad at the back in the middle then the dorr seals etc hold the ret up if that helps
Old Oct 29, 2005 | 06:53 PM
martinrs500labatts's Avatar
martinrs500labatts
three cars but all different
Old Oct 29, 2005 | 07:50 PM
Alan s1's Avatar
Alan s1
martinrs500labatts That last one is a great help as i can see how i got to cut my Dash as mine comes down the front in the same place Im not looking folward to doing that part of it tho As the dash is Very Clean
Its still not in the car right tho removed the rear half so i could get the front bars in right as it would'nt fit right , could'nt get the bar in that runs along the top of the screen But know is
Some pics of the mess i have made Tomorrow
155lee
Aug 14, 2015 11:21 AM
saph in dorset
Aug 14, 2015 10:10 AM
41
Aug 7, 2015 08:58 PM
col93saphcos
Aug 7, 2015 03:21 PM
