cossie gear box
Old Oct 27, 2005 | 09:42 AM
DAN P's Avatar
DAN P
Default cossie gear box
does any one no how many bolts hold the box in on a 2wd saff as i cant seem to find last one
thanx for any help
Old Oct 27, 2005 | 09:57 AM
DAN P's Avatar
DAN P
any body ???
Old Oct 28, 2005 | 09:31 AM
Matt's Avatar
Matt
4 bolts hold box to bellhousing
2 bolts hold hanger to chassis
Old Oct 28, 2005 | 09:52 AM
900ss's Avatar
900ss
RWD Racer
4 nuts hold xmember to the floor
Old Oct 28, 2005 | 10:13 AM
SPADGE's Avatar
SPADGE
7 bolts hold the box to the engine inc the 10mm one holding the plate between box and engine + 3 starter motor ones. There are just 4 others bolting the crossmember to the chasis.
Old Oct 28, 2005 | 10:17 AM
SPADGE's Avatar
SPADGE
Don't know what Matt and Wyn are talking about as there are deffo 6 main bolts holding box to engine! 2 at the top and 2 down each side!
Old Oct 31, 2005 | 05:38 PM
900ss's Avatar
900ss
RWD Racer
........ But you only need to remove the 4 that secure the box to the bellhousing to remove the box
Old Oct 31, 2005 | 05:42 PM
B11GNS's Avatar
B11GNS
Why do some people remove the 4 bolts to the bellhousing, leaving the bellhousing in there, surely its easier removing the bellhousing from the engine the normal way
Old Oct 31, 2005 | 05:55 PM
900ss's Avatar
900ss
RWD Racer
Unless something else needs changing or inspecting then no need.
Old Oct 31, 2005 | 05:57 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
don't forget to take the gearstick off
Old Oct 31, 2005 | 06:01 PM
900ss's Avatar
900ss
RWD Racer
.....and the plop
Old Oct 31, 2005 | 06:16 PM
SPADGE's Avatar
SPADGE
Wyn that is a shite way of doing it imo
If your going to have the box out its well worth removing it complete with bell housing and check the clutch etc....
Old Oct 31, 2005 | 06:26 PM
900ss's Avatar
900ss
RWD Racer
last word
Rizlablue
Sep 6, 2015 09:58 AM
Adam Graham
Sep 6, 2015 06:04 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
cossirob
Sep 3, 2015 09:17 PM
marky_g
17
Sep 2, 2015 08:44 PM
