Transfer box's / VC's
Old Oct 26, 2005 | 09:53 PM
Kelv's Avatar
Kelv
Almost there!
Default Transfer box's / VC's
In the standard transfer box (Escort Cosworth) what rating is the standard VC in NM?
And to what benefit would there be from fitting a 'pumped up' one while the gearbox is out?
what NM is best to go for when selecting a new VC or shld i just leave it all alone?
Kelvin
Old Oct 26, 2005 | 09:58 PM
Kevin Sharp's Avatar
Kevin Sharp
shameless plug
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE%3AIT&rd=1
thanks kel
Old Oct 26, 2005 | 10:05 PM
Kelv's Avatar
Kelv
Almost there!
Kev, its because of what you have for sale that im asking!!
LOL
Old Oct 26, 2005 | 10:11 PM
Kelv's Avatar
Kelv
Almost there!
Originally Posted by YUM360
That would go nice with my new kit
Bitch!
Only jesting Dave.
Old Oct 26, 2005 | 10:19 PM
Kevin Sharp
happy bidding chaps! btw its a 60nm one i use in the 7 speed now and not a 50 as i said via pm kel
Old Oct 26, 2005 | 10:25 PM
markk's Avatar
markk
the centre vc controls the amount of slip between the front and rear axles, teh tighter it is the less slip
tarmac spec is usually between 50nm and 80 nm
gravel spec can be as high as 250nm
road versions are not too far from 50nm anyway.
but you do need slight slip in a road car so not too tight ( nowhere near kev sharp tight !)
as there are certain circumstances when there will be a differance in speed on the front to rear axles. not only that the tighter they are the hotter they run , and vc DONT like to run over approx 110 deg or they lock
Old Oct 26, 2005 | 10:26 PM
Kelv's Avatar
Kelv
Almost there!
No prob Kev.
Cheers for the reply
kinda makes sense to do it all in one go while im having the step off gears fitted and its all in bits.
Kelvin
Old Oct 26, 2005 | 10:28 PM
Kelv's Avatar
Kelv
Almost there!
markk so to step from a 25nm standard VC to a 50nm VC will be ok for odd road use etc?
Old Oct 26, 2005 | 10:32 PM
Kevin Sharp
Originally Posted by markk
the centre vc controls the amount of slip between the front and rear axles, the tighter it is the less slip
what mark said! ...i wasnt sure on exact specs between tarmac and gravel
Old Oct 26, 2005 | 10:37 PM
markk's Avatar
markk
50 nm will be fine for the road pal, the reason that the competition cars dont use any higher on tarmac is that there wheels dont leave the tarmac, hence there is never and differance in speed between front a rear axles, where as gravel - well fook me - how much differance to you want to try and control !!
Old Oct 26, 2005 | 10:42 PM
Kelv's Avatar
Kelv
Almost there!
Cheers!
A new little lesson learnt by myself
i could go to the top of the class at this rate
Old Oct 26, 2005 | 11:10 PM
markk's Avatar
markk
Originally Posted by kelcos
Cheers!
nahhhh ............ you'll still be one step behind me
glad to help pal
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
