Whys my Stack Rev counter reading double then !!!!
Old Oct 26, 2005 | 09:20 PM
Tony Ryan's Avatar
Tony Ryan
Default Whys my Stack Rev counter reading double then !!!!
My Stack counter reads way over what it should , double maybe , ive been told to say the cars on P8 and coilpacks ! Whats the crack with that then !
Old Oct 26, 2005 | 09:45 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: Whys my Stack Rev counter reading double then !!!!
can you select the amount of cylinders on your stack? if so try 8
Old Oct 26, 2005 | 09:48 PM
kevmk2's Avatar
kevmk2
Thats what i done with mine,mines dizzyless and 2 ignition modules. You may have to try it on 2 cylinder also
Old Oct 26, 2005 | 09:51 PM
Martin-Hadland
was just trying to remember if it was 2 or 8 that i used on mine!!
Old Oct 26, 2005 | 10:00 PM
kevmk2's Avatar
kevmk2
Yeah i couldnt remember either lol
Old Oct 26, 2005 | 10:03 PM
Ryan's Avatar
Ryan
there you go tony.
im sure you can sort that.
If not i could do it on the up and coming test day.
could bring a laptop, and make use of the pectel logging facilities to see what the car is doing
Old Oct 26, 2005 | 10:05 PM
AlexF's Avatar
AlexF
2 coils = wasted spark
ie two sparks per 180 degrees
set it to 8 cyl and everything should be fine
IIRC..
Alex
Old Oct 26, 2005 | 10:29 PM
Lee @ Fusion's Avatar
Lee @ Fusion
cant rember what i had to set my SPA to , 2 i think , but u get the idea by now tony
Old Oct 27, 2005 | 05:01 PM
#13's Avatar
(sorry Tony couldnt resist) (cars looking good!!)
Old Oct 27, 2005 | 05:46 PM
GARETH T's Avatar
GARETH T
IIRC..
Alex
nope it should be on 2 cylinders,, as the coil pick-up for the tacho is only off one side of the coil pack, so it misses two counts every rotation
Old Oct 27, 2005 | 06:12 PM
ian sibbert's Avatar
ian sibbert
With a coil pack tacho should be 2 cylinder....
Old Oct 27, 2005 | 06:13 PM
DaveEscos's Avatar
DaveEscos
what do i do to sort my std rev counter out on my esc cos?
p8, coilpacks
Old Oct 27, 2005 | 06:15 PM
Ryan's Avatar
Ryan
dave speak to Ahmed, i think he can sort something out through SECS
Tony Did you sort it?
Or is the car now at Simons?
Simon, meant to catch you down at tony's but was a little rushed, was going to have a word about spraying my car
Old Oct 27, 2005 | 06:16 PM
markk's Avatar
markk
p8, coilpacks
pulse doubler or remove the shonky inacurate std revcounter
GARETH T's Avatar
GARETH T
p8, coilpacks
get some tip-ex out and write new numbers over the top
or build/buy a frequancy doubler (i think secs sell them)
Old Oct 27, 2005 | 06:22 PM
Damo V's Avatar
Damo V
p8, coilpacks
Dont do this dave I have already tried it, when you turn the lights on its obvious its not a factory setup
Ahmed, SECS...????!!!!! Jesus they must be about the two most elusive people in the country
Old Oct 27, 2005 | 06:23 PM
DaveEscos's Avatar
DaveEscos
pmsl... SECS oh lordy!
Old Oct 27, 2005 | 06:28 PM
#13's Avatar
Hi Rayan. What you after? Am in the middle of doing tonys now, will be very bright when done!!
Old Oct 27, 2005 | 07:43 PM
Tony Ryan's Avatar
Tony Ryan
Cheers for the replies, Reckon it needs setting for a 2 cylinder, wonder if this can be done on a ST400 - surely ??
Also Ryan the Boost gauge should sit at 1 bar , so i think weve got a problem with the wiring somewhere ! saw Scottys today and he put me straight !
Si , Get us some pics of the car then !
Old Oct 27, 2005 | 07:46 PM
#13's Avatar
Tony you would cry if you could see your car at the moment!!
Old Oct 27, 2005 | 07:49 PM
Tony Ryan's Avatar
Tony Ryan
As long as it isn't fookin yellow i dont care , lol !
Bought some more wheels today , guess what colour the centres are .........
Yellow !!! AAAh hhhh
Old Oct 27, 2005 | 07:51 PM
#13's Avatar
its all sorts of random colours at the mo!!! Hope you like runs??? jus kidding!! your wheels are wider than my fiesta!
Old Oct 28, 2005 | 07:34 AM
Porkie's Avatar
Porkie
Ryan, get in the queue Simons painting my Sierra after he paints Tonys
Old Oct 28, 2005 | 07:38 AM
Ryan's Avatar
Ryan
lol porkie
ok. I'll wait
Simon, basically want a price on painting the car, inside, out and underneath.
The car is a complete shell on a dummy jig.
Tony, hmmmm now there's a odd one, will have to look at the wiring on the test day.
Old Oct 28, 2005 | 07:55 AM
Martin-Hadland
p8, coilpacks
use a rev counter from a small turbo esc cos?
Old Oct 28, 2005 | 07:59 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
p8, coilpacks
Only one part number is now listed for the Escort rev counter, so no good .
Old Oct 28, 2005 | 08:08 AM
justin.e's Avatar
justin.e
Dave,
bin the bloody thing,the cars crying out for a stack
Old Oct 28, 2005 | 08:17 AM
Martin-Hadland
p8, coilpacks
secondhand.. donut
Old Oct 28, 2005 | 08:45 AM
DaveEscos's Avatar
DaveEscos
good idea martin
surley kevin mchaggis has a small turbo rev counter Mike
Old Oct 28, 2005 | 09:05 AM
Damo V's Avatar
Damo V
Will the ST rev counter defo work ok?? Did they not simply work round it within the EEC-IV ECU??
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Mc5506
Sep 29, 2015 09:06 AM
