Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
xr3i nightmare
Old Oct 24, 2005 | 06:23 PM
robbob's Avatar
robbob
Default xr3i nightmare
can any one help i have a mk4 escort xr3i the efi version the problems are when im driving and say pull upto a junction the revs drop and the engine cuts out it starts straight away again also when driving especialy around town the car seems to jerk and is hesitant what could it be help
Old Oct 25, 2005 | 12:44 PM
ScORTED's Avatar
ScORTED
Project Money Pit
plugs.. leads... first point of call
Old Oct 26, 2005 | 06:35 AM
Paddy's Avatar
Paddy
Legend
try cleaning out the breathers too
Old Oct 26, 2005 | 07:23 PM
robbob's Avatar
robbob
plugs and leads are fine checked the breathers ther ok to any other ideas
Old Oct 28, 2005 | 02:15 PM
Paddy's Avatar
Paddy
Legend
is there excess crank pressure? take the oil cap off and see if it stalls
Old Oct 28, 2005 | 03:50 PM
robbob's Avatar
robbob
took the cap off and it ran fine
Old Oct 29, 2005 | 09:17 AM
Paddy's Avatar
Paddy
Legend
Thats good news! could have been expensive....
next step would be to clean through the throttle body then could be a potentiometer/throttle switch problem.
Old Oct 29, 2005 | 07:42 PM
robbob's Avatar
robbob
cleaned the throttle body little bit better what was that other thing you mentioned
Old Oct 29, 2005 | 10:47 PM
MadMac's Avatar
MadMac
potentiometer is the module on the side of the throttle that reads how far open it is.
Old Dec 23, 2005 | 02:22 PM
rstrob's Avatar
rstrob
Its your idle speed control valve it happened on my old 3i and now on my cabby.On my old car i replaced nearly everything before i changed it.But when you order one be careful as there is 2 types hitachi and bosch different no of houles one is 80 the other is 120.the bosch is more expensive hope this helps.
Old Dec 27, 2005 | 01:27 PM
JamesRSTurbo's Avatar
JamesRSTurbo
message missing
Old Jan 23, 2006 | 08:48 PM
nosman's Avatar
nosman
Hi there,
That happened on my xr3i (90spec with efi engine). I changed the plugs, leads, mixture pot(on inner wing), cleaned the idle control valve, air filter, all to no avail.
The result was that the throttle stop bends on the throttle body, try opening it a couple of thou, by bending it slightly and im pretty sure that will fix. It doesnt cost you anything either!! I think they just bend after thousands of throttle opening and closings.
Old Oct 16, 2012 | 11:27 PM
bigal111's Avatar
bigal111
How do a get my 3i to idle
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
