My series 2 turbo not running right !! help!!
Old Oct 17, 2005 | 11:09 PM
Tracy1's Avatar
Tracy1
Default My series 2 turbo not running right !! help!!
My turbo is running a stage 1 chip bleedvalve and dash 31 actuator, recently my boost gauge is hitting nearly 17 psi, and my bleedvalve has been turned down (although i think its sticking) do i need to remove my bleedvalve help me incase my engine siezes
Tracy x
Old Oct 18, 2005 | 12:07 AM
wildheart's Avatar
wildheart
I'd personaly get it set upby a profesional like MSD or Turbosystems or it could all end in an oily mess!
Old Oct 18, 2005 | 10:20 AM
GrimmeRS2K's Avatar
GrimmeRS2K
buy a new bleedvalve a brass one is best and start by turning it down as much as it goes, and see what boost ur running, then turn it up to whatever boost u were running before,
only turn small amounts though, or as above take it to a tuner.
Old Oct 18, 2005 | 01:25 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
part time model. PICS please
Turn the bleed valve right down, then see what boost it's at.
Old Oct 18, 2005 | 01:26 PM
Combi_Chris's Avatar
Combi_Chris
omg its the same on this forum too, lol
Old Oct 18, 2005 | 06:12 PM
Tracy1's Avatar
Tracy1
Default Getting it set up!!
Hi all,
Thanks for all your advice not going to mess just incase!!! taking it to severn valley to have it looked at and hopefully she will be back to her old self!! poor girl!! thanks all xxxx
Old Oct 18, 2005 | 06:43 PM
vroooom ptssssh
It Wasnt Me!
well wheres these pics
Old Oct 19, 2005 | 09:55 AM
Combi_Chris
i think you need to look at that persons www link....................
Old Oct 19, 2005 | 11:26 PM
Tracy1's Avatar
Tracy1
Default pics!!
www.tonidavies.com
xx
Old Oct 19, 2005 | 11:38 PM
GrimmeRS2K's Avatar
GrimmeRS2K
nice pics
watch the views on this thread go sky high now
Old Oct 19, 2005 | 11:53 PM
vroooom ptssssh
It Wasnt Me!
Im on my way, i'll fix it, pick me, pick me
If you cant wind the bleed valve back in, take it off, how is the amal valve piped up, if it is still there? if its not in use, dont take the bleed valve off, as im not sure what iwll happen
Old Oct 19, 2005 | 11:54 PM
vroooom ptssssh
It Wasnt Me!
p.s. msn addy?
Old Oct 20, 2005 | 12:25 AM
Combi_Chris
thats a wicked site too, as well as the piccys
Old Oct 20, 2005 | 12:54 PM
wildheart's Avatar
wildheart
not bad
Old Oct 23, 2005 | 09:55 PM
Mr RS's Avatar
Mr RS
what do you want a bleed valve for all they do is tempt you to turn the boost up resulting in melted pistons, get it set up right and leave it alone, thats the best idea i think
Old Oct 23, 2005 | 10:16 PM
DaveN's Avatar
DaveN
Thats right listen to what MR RS says (loose the bleedvalve) or get it setup from a specialsit and dont touch it..
Regards.
Old Oct 24, 2005 | 12:58 PM
EssexMikeSi's Avatar
EssexMikeSi
thats what im gonna do with mine. wen it gets taken to be set up im gonna get em to remove the bleed valve
Old Oct 24, 2005 | 08:25 PM
rsbill's Avatar
rsbill
Default bleed valve
hi would take of the bleed valve and turn the boost down to holding 13 and peakiing at 14 if its not holding boost then change acuator or could be boost hoses collapsing and then get the timming set spot on and get fuel air mixture set hope that helps you matew..
Billy_RS
16
Oct 11, 2025 09:41 PM
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
turbobill
Aug 9, 2015 05:21 PM
adriansaleem
Aug 1, 2015 09:28 PM
