boost
Old Oct 17, 2005 | 03:56 PM
turbo-dave718's Avatar
turbo-dave718
Default boost
What sort of safe boost level can you run before you need to change the pistons for low compression ones? Also will the metering unit cope with the fuel side?
I've got a piper x air filter, exhaust, chip, actuator + bleed vaulve, running at 12 psi. After a bit more power and cant decide on front mount intercooler or a cam. I can only afford one for now, intercooler will look cool though and i hear the standerd one is only ok for 14psi max.
Any advise much appreciated.
Old Oct 17, 2005 | 04:15 PM
DazC's Avatar
DazC
It is all dependant on your ignition timing and fueling.
Old Oct 17, 2005 | 04:41 PM
GrimmeRS2K's Avatar
GrimmeRS2K
dont bother with a cam IMO, a FMIC will be a better opition, and looks good for your money,
a standard cam is pretty good anyway,
Fuelling as said many times, take it to a decent tuner and they should help u.
I put low comp pistons in mine as a pre caution and i wanted to rebuild the bottom end anyway, standard compression should be ok up to 18 psi or over as said above depends on timing and fuelling,
my mate runs new standard comp mahle pistons running 20 psi, and his is fine, but every cars different
Old Oct 17, 2005 | 04:57 PM
turbo-dave718
Thanks for the replies. Think I'll leave the cam then and go for the intercooler. Been looking at the radtec front mount as it seems best vaule for money, about £330 inc p+p and twin fans, has anyone tried these? Or are pace etc worth the extra?
Trip to interpro after then to get it set up, last thing I wana do is blow the engine.
Cheers guys.
Old Oct 17, 2005 | 05:00 PM
GrimmeRS2K's Avatar
GrimmeRS2K
IMO id spend the little extra and go for the Pro alloy one, i run a GRS with 2 fans, but mine was cheap second hand.
Old Oct 17, 2005 | 07:02 PM
kiddie's Avatar
kiddie
go for a frount mount pace, its the NUTS
Old Oct 18, 2005 | 08:03 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
I have tested several intercoolers lately ........
GRS all the way
Old Oct 18, 2005 | 10:15 PM
GrimmeRS2K's Avatar
GrimmeRS2K
GRS all the way
have u gone back to a GRS Tony? thought u had a pro alloy?
Old Oct 19, 2005 | 04:24 PM
Tony Turbo's Avatar
Tony Turbo
Worst thing I did was to ditch my old one in the first place
Still, you live and learn. I can see a trend happening here........
Old Oct 19, 2005 | 04:33 PM
GrimmeRS2K's Avatar
GrimmeRS2K
glad i kept mine then, i was gonna change to a pro alloy,
Big up GRS!
Old Oct 19, 2005 | 05:02 PM
dave_y's Avatar
dave_y
does that intercooler bolt straight on, im after a front mount intercooler but i don't want to start butchering my front bumper?
and also i assume they come with the twin fans to chill out the radiator...?
Old Oct 19, 2005 | 05:05 PM
GrimmeRS2K's Avatar
GrimmeRS2K
they do just bolt straight on if u take your time, the fans are extra, about 90 quid each
its a tight fit, but with some time u can get it on,
Old Oct 19, 2005 | 05:24 PM
Oranoco's Avatar
Oranoco
My Pace was a doddle for me to fit and is the bollocks
Was only a doddle as I couldn't be bothered and just paid SCC to do it. Bill wasn't too heafty so doubt it was too bad
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
