*sold*
Oct 16, 2005 | 08:13 PM
*sold*
*sold*
Oct 16, 2005 | 08:55 PM
Does this have valve cut outs to get the lower compression??
john
Oct 16, 2005 | 09:03 PM
Quote:
john
No, brand new 4x4 pistons which in a 2wd bottom end give that comp ratio
Oct 16, 2005 | 09:07 PM
Quote:
Originally Posted by robbieg
What is a '202' block?
Transit power
Basically it's thicker walled like the 200 block.
It also does not have big core plug the back of the block which can cause 200 blocks to split lengthways.
The only downside is the fact it can't be longstudded which was never an issue for me as I don't like longstudding.
An alloy head needs room to expand.
Basically it's a vast improvement on the 205 block and swings and roundabout compared to the 200 block.
I went that route following advice from my engine builder and wouldn't hesitate to use 202 blocks in any power build
Oct 16, 2005 | 09:27 PM
would a 4x4 head with bd 14 cams be ok and not hit??
john
Oct 16, 2005 | 09:46 PM
john
Hmm, I have heard of people using BD14 without cut outs but I think it's the exception rather than the norm.
Wouldn't like to say either way.
I can measure the gap at TDC with my verniers if you like?
Doubt if it would be to expensive to pop the pistons out and pocket them tho
Oct 19, 2005 | 09:50 AM
Has the crank been reground?
Was the block line bored?
Few more details about the build please if possible.
Oct 19, 2005 | 01:15 PM
Provisonally sold. Awaiting deposit.
*edit* Deposit a no show
Back for sale
Oct 19, 2005 | 04:01 PM
...just to point out GurnE long studs are semi stretch
Oct 19, 2005 | 04:25 PM
Didn't your own block crack around the bolt holes when using long studs Phil?
Oct 19, 2005 | 05:37 PM
gurnE no it cracked cause i WASNT using long studs!...I was on STANDARD stretch bolts.With a T4 blowing 2.2bar it was a little too much for em
Oct 19, 2005 | 08:08 PM
Nov 10, 2005 | 06:30 PM
Deposit ain't turned up
Bloke reckons he sent it to the wrong account by mistake but has failed to ring me back so it's back up for sale
Nov 10, 2005 | 06:54 PM
give you £1k for it and if you deliver to essex all your expenses as well
Nov 10, 2005 | 07:25 PM
Nov 10, 2005 | 07:28 PM
well the cash is in my pocket if you change your mind!
Nov 10, 2005 | 07:59 PM
fair play for trying though
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
fordrallycar
Sep 30, 2015 07:57 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
